Audio jack
Anyone else deal with a lot of static noise when using your audio jack? I try to listen to iTunes through that jack and it sounds like crap. Now it doesn't work at all. Should I be looking for a loose connection somewhere? Perhaps under where the input is?
My apologies for not being more of a help with the port not working at all. Maybe a fuse??
Yup, I'm talking about the auxiliary port...mine seems to have stopped working entirely now.
There is TSB in which they install a line filter to stop noise from the aux jack. I had it installed in my 07 LS460 and it worked. Cost about $150 to buy and Dealer installed for about $80. You might be able install yourself.
I bought the filter at Sewell parts on-line and installed myself. Part was pretty inexpensive and installation was easy.
