Trim Wrap
Old 04-05-15, 06:25 AM
Vettcross
Vettcross's Avatar
Default Trim Wrap
What is the best way to re glue the wrap around the trim as it becomes detached. and BTW who at Lexus thought that was a good idea?
Old 04-05-15, 06:29 AM
greg3852
greg3852's Avatar
Could you be a little more specific as to what you are talking about?
Old 04-05-15, 06:31 AM
Vettcross
Vettcross's Avatar
The trim that runs from the from front window, over the roof and down the back window on both sides of the car.
Old 04-05-15, 06:34 AM
greg3852
greg3852's Avatar
ahh gotcha. I have no idea but would like to know. Mine has a small crack in it, so I'll probably be replacing it soon. I saw one flapping loose on the highway once. I'll definitely keep an eye on this thread. Someone may have an answer soon.
Old 04-05-15, 06:36 AM
Vettcross
Vettcross's Avatar
I am thinking basic trim adhesive but was interested to see what others may have done.
Old 04-05-15, 08:12 AM
roadfrog
roadfrog's Avatar
Those are held by clips. Anytime the windshield is replaced, those trim pieces need to be removed. If you had a recent windshield replacement, you should go see the shop that did it to make sure they didn't break them. They do break easily.
Old 04-05-15, 07:57 PM
Lextrician
Lextrician's Avatar
The clips are pretty cheap recommend getting some new ones so that you have a few laying around. Just in case
Old 04-07-15, 04:56 AM
lbintab
lbintab's Avatar
I think the trim is separating correct? Is probably still clipped in but the part that's painted is coming up. Any heavy duty glue should work. If that ends up failing then at that point replace that whole part
Old 04-07-15, 05:46 PM
Vettcross
Vettcross's Avatar
Default Thx
Thanks lbintab- You are correct and that is what I had in mind. Is this a common occurrence?
Old 04-08-15, 05:51 AM
Fhobbs
Fhobbs's Avatar
I had a similar problem and posted pictures in another thread. Any glue and adhesive would not work. Very hard to get in place. Having said that, it would be best to remove the trim in its entirety before trying to glue (maybe you would be better at glueing it than I). I wound up replacing the trim on both sides purchased from Lexus Parts on-line. About $250 per side. Replacement was very easy. Took 30 minutes at most.
Old 04-09-15, 08:44 PM
BigWalt
BigWalt's Avatar
Strips are about 540 each, I called lexus about mine and they agreed to split the cost of the parts with me.
I opted to handle it on my own since I was getting my replacements for really cheap from a friend.
There is no way to really repair it long term that I found, I hated how ugly it looked so having mine replaced this weekend.
Old 04-10-15, 10:27 AM
Vettcross
Vettcross's Avatar
Default Trim Fix
Mine has not gotten too bad yet. They are structurally sound. I am thinking that I will pop them off and paint them body color- base/clear.
Old 04-10-15, 11:17 AM
BigWalt
BigWalt's Avatar
I believe someone posted that they were not able to be painted, best of luck tho. Keep us updated.
Old 04-10-15, 11:22 AM
Vettcross
Vettcross's Avatar
Well I don't like the sound of that. I had read that a few had painted their black and not body color. I guess sI will have some gloss black film on as a backup if they are not paint-able.
Old 04-11-15, 12:48 PM
keegan500
keegan500's Avatar
Mine did the same thing. Wrap peeled off about a foot and a half and exposed a not so pretty chrome underneath. Getting both strips and roof wrapped black carbon fiber for 300. I thought that was a better route than taking them off and painting them myself.
Quick Reply: Trim Wrap
