F-sport height value
Hello everyone. I am interested in the value of the height pneumatic suspension in complete f-sport. It is no secret that on standard suspension height values as follows: 98 mm front, rear 93 mm., f-sport package differs lowered by 10 mm suspension height. I configured my car on the following values : 108mm front, rear 103mm. If I did? I am interested in the values in the repair manual it is intended for the Assembly of f-sport.
The values for the settings are obtained as follows : A - the distance from the control arm bolt to the ground. b - the distance from wheel center to the ground. b-a= 98mm (in standard configuration) . Rear measurements are the same: C-value from the notches in the cross arm, d is the distance from the center of the rear wheels to the ground. D-C=93mm.
