LS460L air suspension to regular shocks?
Old 04-27-15, 01:41 PM
Zeke21
Zeke21's Avatar
Default LS460L air suspension to regular shocks?
Is it possible to replace a failed air suspension in a 07 LWB with the standard shocks/system?
Has anyone on the forum actually done this that can provide some details. Appreciate the insight.
Old 04-27-15, 01:52 PM
Devh
Devh's Avatar
Yes you can easily do so but you may run into an issue with a light on the dash. It might be possible to gut the harness from the air suspension and plug it in.
I believe I seen a vendor on the internet long ago with all of the assembled struts with springs for $1000 for those that wanted to do the conversion.
If I had bought a car with air suspension and one of the units went bad down the road I would have sold the remaining good ones and used that money to finance regular suspension.
Old 04-27-15, 02:52 PM
Lavrishevo
Lavrishevo's Avatar
KYB is the oem manufacturer. Check out Rockauto. You will need your springs and mounts and some bolts for the mounts. I'm sure others who have done the conversation can chime in. Coilovers are also an option. If you leave your height sensors in place, adjusted properly, and just kill power to the compressor you should not have any warning lights on your dash / confusion with the air suspension computer. Or just swap out a good used unit.
Old 04-27-15, 04:08 PM
njumongkol
njumongkol's Avatar
How do you kill power to compressor?
Old 04-27-15, 04:16 PM
Devh
Devh's Avatar
Here is a member that has done the conversion.
https://www.clublexus.com/forums/mai...-coilover.html
Old 04-27-15, 04:36 PM
Lavrishevo
Lavrishevo's Avatar
Pull the fuse or disconnect it at the compressor itself.
Old 04-27-15, 06:31 PM
Tec80
Tec80's Avatar
Even better, remove the compressor and sell it on eBay.
Westduck
06-19-19 10:11 AM
Sailcail
04-17-19 10:56 AM
nc7760
Maintenance
05-06-16 05:37 AM
lsdude
10-06-15 01:33 PM
Jbthompson
07-30-12 03:26 PM
Quick Reply: LS460L air suspension to regular shocks?
