Long term storage
Chris
I hear what you are saying man but I just could not do it. I would have spent the whole time in HI worrying if it would short out, or if the house got hit by lighting and the surge ended up in the LS electronics. When we leave for the winter we unplug everything we can inside the house.
Dennis
Dennis
I had the same question last fall when we were getting ready to go to HI for the winter. Now we were only going to be gone 3 months not 6. In the end I could not make myself go off and leave a hot battery tender/charger plugged into the wall even though the garage is heated and cooled and hooked up to my LS unattended for that long. I think the battery tenders are great if you or someone else can eyeball it every once and awhile. In the end I topped off and treated the fuel made sure everything that I could I shut off and left the battery hooked up. When we came back the LS cranked slow at first then fired right up. I have doubts that it would have fired up after another 3 months. I believe the key here would be to have a good battery with a full charge on it when you left.
Dennis.
Dennis.
The risk with supplemental chargers range from failure of the charger, which is low, to failure of the chargers power source from power line transformers caused by storms, electrical and wind, automobile accidents and all manner of things, that might propagate into your car's electrical system via the "tender" and damage it, all very unlikely but not a risk worth taking. There's just not much to be gained and not worth giving it much thought in most situations.
I think that leaving the battery connected, without a supplemental charger, while the car is idle for extended periods would be Ok. If the car starts, drive it for a while to recharge the battery and then have the battery's "state-of-charge" measured and if it is in a normal range then you are all set for a while. If the car will not start after being idle for extended period then fully charge the battery with a charger, measure the state-of-charge, and if it is in a normal range you will be set. Any time the state-of-charge is low after the battery is fully charged then it is time for a replacement. State-of-charge can be easily measured with an inexpensive voltmeter. You can also determine the state-of-charge using an inexpensive hydrometer that is available from auto parts stores.
My only concern with a drained battery is when it sits outside in freezing temps and the battery has drained. That will permanently destroy the battery. The better option would be removing the battery and placing it in a warm garage etc.
You guys in the "Far North" use heater blankets on your batteries? You have much different considerations than us folks way down here. Using a battery heater seems like a low risk approach if your climate involves extremely low temperatures.
I'm in FL and had spent most of my working life around big boats/yachts that have multiple lead acid batteries on board. Besides starting and running the engines they are necessary to run automatic bilge pumps that operate on a float switch 12v. There is a battery charger on board that has the capability of putting out 20-50 amps typically and as little as 0 amps as the batteries require. The boat is plugged into shore power. Many of the boats are gasoline powered with the fuel tanks located in the engine compartment along with the batteries and the charger. The charger does have technology to prevent sparking which could cause an explosion if gas or battery fumes were to build up. Point is everything is plugged in 24/7 365 days a year. Even when the boat is operating, if equipped with an a/c generator, the battery charger is on. Is this a fair comparison? I'll leave it to you...
Well actually, this is the kind of circumstances where battery tenders are intended and designed for, (NOT checking on them once in a while). Battery CHARGERS on the other hand, should be checked.
Putting your battery into a level of discharge like you do will only shorten the life of it. Your car's electrnics don;t like it either.
IF you Don't want to go thru all these things, the Easiest thing would be to let one of your Friends or Neighbors just check on Everything for you & crank your car from time to time & maybe drive it to the mailbox & back! Do any of you Not have ANYBODY you live next to you can Trust?
This must be the First time you've did this, IF NOT what did you do the times Before?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I took the long way around to make the point that batteries (under much more hazardous conditions) can be hooked to a charge maintainer for long periods and nothing bad happens.
^^THIS! I have a Battery Tender on my 911 & i've Never had a Problem with it getting Hot, like RF said this is what they're FOR! I can't believe you Don't come back at all during the whole 6 months (i know i couldn't go that long without driving my Babies, Lol)! Why do you Not just drive it to Florida, after all it IS a Lexus (just the Best Road Trip Car Made) & it'd be Nice to Cruise around Fla. in Luxury! ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
How many and what sort of problems do you think you would have had if you did not use a battery tender, other than extending your battery's life and how many months do you think you extended its life. Keep in mind that the battery tender will not prevent battery failures that are caused by latent manufacturing defects and poor maintenance that allows the cell plates to become exposed to the air.
I think the point you are making, perhaps inadvertently, is that it is a risk worth taking, in the case of the bilge pumps.
I try not to take risk in which the risk/reward ratio does not support the risk. Insurances underwriters have deductibles that shift that ratio to be in their favor.
Johnnyreb
The DW has only driven the LS 4 or 5 times by her self in 10 months. Can you imagine the rash of $%^& I would catch if I left the keys with a neighbor and said go ahead and take her for spin every now and then while I am gone. I have almost 48 years invested in this marriage plus 17 years in hot pursuit so that is not likely to happen.
Dennis
Dennis
