Air Suspension on a Used LS460
It was my BIL 2009 Escalade. It was complete junk worse then the Lexus. If they improved the system in the newer GM cars then it will be a pleasant surprise. Incidentally my BIL traded up last month for the new 2015 Escalade platinum edition and I will see this month how much better it is.
I'm open to driving the new one to see if it does.
If the system works well for GM then that's great. The corvettes of the last 10 years are pronominal cars in just about every aspect of weekend racing.
I am also surprised by how many of you say you can't tell the difference between sport and comfort settings on the LS. Sure it doesn't turn a boat into a track car, but there is a distinct and noticeable difference in each of the 3 settings.
With the air suspension they are always shocks, not struts. I thought on the 430 and 460 regular suspension Lexus uses shocks not struts. I could be wrong but I am pretty sure struts are not used.
The major difference between shocks and struts is that a strut is a structural part of the vehicles suspension system where a shock is not. A strut is also crucial part of the vehicles steering system and greatly affects alignment angles. Camber and caster angles are usually adjusted right on the strut itself. A strut is also a pivot point for the vehicles steering system and contains a coil spring. Because of this an alignment is always needed when replacing a strut. This is also the reason that struts are typically more expensive than shocks.
I could tell the suspension modes in the LS with air, I'd just never use them. Never used the AVS in the GS.
I plan to buy a 2007 460L in the next month or so. I don't see where there are too many problems in 100K mile cars, but I sure don't want a big repair bill just for a comfy ride.
My GX and LS both have air suspension. I could easily feel/tell the difference between all three settings. When I was in the market for LS, I was looking for air suspension among other things in spite of having air suspension work done on GX under warranty. I really enjoy air suspension on LS in highways, turn on ML and enjoy best of both world while on motion !!!
jdubbsISF
03-04-16 10:23 AM
