lower arm control driver side
Old 07-10-15, 06:38 PM
anucci
anucci's Avatar
Default lower arm control driver side
2011 ls 460 l has setting on driver side only not passenger does any know WHY? thx anucci
Old 07-10-15, 07:33 PM
Devh
Devh's Avatar
Interesting. That's an eccentric bolt.
Does the car have an accident history.
Old 07-10-15, 07:45 PM
FIGS
The Maker
FIGS's Avatar
are you talking about the connection for the headlight auto leveling? I believe the factory equipped air models use this for height feedback so it would be on all 4 corners.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 07-13-15, 07:50 PM
texas008
texas008's Avatar
I checked and my LS460 is the same, i.e., with a small link on the middle of the driver side lower control arm, but not on the passenger side.
Old 07-17-15, 11:24 AM
anucci
anucci's Avatar
Mike
thanks mike I got it made my day.
Old 07-18-15, 08:56 AM
roadfrog
roadfrog's Avatar
My non air LS is similarly equipped. I have the AES lights (headlights turn and level when going around corners etc).
Old 07-18-15, 10:16 AM
Doublebase
Doublebase's Avatar
Devh is talking about the bolt that goes through the control arm, into the cradle. It's an eccentric that should allow for camber adjustments, I believe.
xkazman
Performance & Maintenance
04-02-18 10:24 AM
Shiryo
07-30-12 04:19 PM
wald.sc400
09-02-11 09:13 PM
ILOVEGIRLS
Suspension and Brakes
01-19-06 02:13 PM
Quick Reply: lower arm control driver side
