Does the 2012 LS460 Sport Special Edition have rear LSD???
Totally not necessarily. There are very many diff car makes/models that will not list this on the window sticker or even specs. There's a possibility the same can be said for a very limited produced, special edition, Lexus trim, like the MY12 LS460 SE.
If you want to be more technical, it isn't a true LSD because it doesn't "limit" any "slip" and always needs both wheels on the ground to work properly. It is more of a torque biasing differential(ATB), which is basically a different type of open diff. It mimics an LSD.
There are obviously pros and cons to each type of LSD. Start your own thread if you want to get into it. Stop hijacking and changing the topic.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
This thread is closed.
I'm going to suggest you both add each other to the ignore list feature; I strongly suggest this type of thing not spill over into future threads.
https://www.clublexus.com/forums/pro...?do=ignorelist
