Does the 2012 LS460 Sport Special Edition have rear LSD???
Does the MY2012 LS460 Sport Special Edition have a rear limited slip differential???
I’ve tried to google-research this info/answer; but, cannot find anything. I think mainly due to the fact that only 250 were made and also I think they were only produced for MY12 (I could be wrong though). So, there is not much info at all on the MY12 SE.
The only information I could find that was related to an LSD for a MY12, was for the Awd version, in that it has an LSD for the front-to-rear torque-converter. But, no mention of an LSD for the rear pumpkin and/or for the Rwd version.
I know the MY13+ F-Sport lists/states it has a rear torsen LSD. But, I’m wondering if my dad’s MY12 Sport-Edition has one too? (mainly wondering if it’s donuts, drift and track capable, hehe
He recently purchased it about a week or so ago. It's pearl white, with only 15k miles. Looks cherry.
I really want to know if it has a torsen LSD in the rear pumpkin or not. I’m kinda expecting it should have an LSD, and I would be surprised if it didn’t have one. Since a MY12 Sport-Edition has/lists pretty much everything else a MY13+ F-Sport has - Brembos, forged 19s, sport swaybars, sport air suspension, paddle shifters, etc.
I know I can probably check this answer by jacking up the rear, putting it in neutral, then spinning one of the tires by hand...but, it's a big hassle and I'm too lazy to do that (I only work on small cars and never my dad's), my dad will think I'm crazy, I still have to research proper jacking points, idk if I need to switch traction-control off, idk if I need to remove all the plastic underbody panelling off, and the rear-overhang and distance from pumpkin to rear of car is soo long that I'm unsure if my jack will even reach. Just a hassle all around and I'd rather just read the answer.
It doesn't work that way. A torsion or helical limited slip differential works like an open differential and then locks when applying power when one of the wheel slips. It is very hard to detect you have an LSD by jacking up the car and spinning the wheel. An LSD can also create disadvantages depending on the suspension set up and it can introduce more drivetrain loss slowing the cars straight-line speed.
In my opinion an LSD on a car like this will never be realized for the street except maybe better snow performance.
"LSD in a car like this will never be realized" ...I think it's already been realized - MY13+ LS F-Sport Rwds have rear LSD listed.
It's not a locked differential or one that is aggressive like what you find with clutch LSD. When you spin one rear wheel the other wheel will spin in the opposite direction like an open differential. The differential in these newer LSD will lock when enough torque goes through them. I have examined a few cars with the helical torsion LSD's and you cannot tell in all cases by spinning the wheels.
You don't understand why I used the word realized. I know very well that the 13+ has them but it has not much value on the street for this kind of car.
If you still don't believe me please click the link below.
http://websworld.org/marcel/ta23/diff.html
Thanks for the link. Didn't know that. I guess the "spin the wheel" test only works for a few types of LSDs (it's worked on Viscous LSDs I've worked on in the past).
So, back to the Op question:
- Does the MY12 Sport Special Edition have an LSD?
...not looking for a debate on if it's needed for street use, or if there is proper suspension tuning to match the LSD, etc., etc. Because that debate is very subjective and can go on forever - depending on driving style and intended usage (comfort street cruising (95% of LS drivers out there and as it was intended to be), or canyon carving, or track days, or autocross, or immature hoonigan'ry and drifitng, etc, etc.). Yes, I know LSD will not be "realized" during normal street driving 90% of the time (unless stuck in the snow or mud).
I'm just looking for a simple Yes or No answer.
I'm simply wanting to know if the MY12 LS460 SE has an LSD, like that of a MY13+ LS F-Sport
I looked into it by doing a simple google search because I was curious and it appears you don't have an LSD. Even if you did this type of LSD is not good for drifting.
Thanks for the answer. But, do you have a link to that info??? I'd love to see/read it. Like I said in my original post, I too did a "simple google search" but did not find any hard facts.
That is also super subjective. ANY type of LSD is better than NO LSD. There are many different levels of LSD (clutch, 1.5, 2 way, race or streetable, helical, viscous, etc., etc.), as well as many different levels of drifting (occasional, being a hoonigan ***** on the streets, weekend track/skidpad drift days, amateur, professional). Eg: Of course something like a factory Viscous LSD is not "super good for drifting;" but, it honestly still works and is still sufficient enough for the non-hardcore. And most importantly, it is better than No LSD at all.
Again, I don't feel like getting into a debate, or know-it-all ego-induced contest. You obviously sound like you just want to talk me down, prove me wrong and say what is and what isn't "correct. You want to stick everything "in a box." Stop being one of those typical car-forum d*ckheads.
Haha..why yes I am ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I was providing information and opinion which you needed because you did not know otherwise you would be spinning your wheels pun intended without a clue, your welcome . Also noticed that nobody else is on this thread since you posted but I volunteered and even searched to provide you information and this the thanks I receive. The reason why I posted commentary is in hopes that someone else would join in and continue the conversation about the LSD equipped vehicles for this car which is a benefit to everyone even if it's debated. If you don't want to debate that's fine don't add any commentary.
You don't own this thread or control it's commentary so stop being one of those people who feel like they are being talked down to to cover up your lack of knowledge about torsional LSDs.
Only you can come to terms of dealing with your own disappointment of being wrong and be benefited with knowing correct information that maybe a benefit to others.
Easiest way to tell is switch off the traction control and punch it. See if it leaves two skid marks lol.
Of course I don't know if the engine/transmission computer will give you max torque from a dead stop, a lot of newer cars have a feature called "torque management" to where the computer will retard timing, not open the throttle all the way, or find other ways to cut power so there isn't as big of a shock on the drivetrain, even with traction control off.
Another way to tell is to have one wheel on the grass on the other on pavement and have someone observe the behavior.
The easiest way to find out is though the VIN number or original dealer window sticker as they will always list the LSD in the notes if it is equipped.
I don't know about any max torque restriction but I imagine that the fuel cut in neutral is set much lower then when the car is moving or in gear.
It would be very hard to get the LSD to work for you considering the transmission is a bit on the lazy side of shifting.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Happy? You've proven my point about yourself.
