Was the Control Arm issue prevalent in '09
If it's simply the bushings that are going bad, then it's more of a comfort thing and less of a safety issue?
It's the bushings. I've never heard of a failure of the arm portion of a 4LS control arm, either OEM or aftermarket. I'm still reluctant to trust the aftermarket parts based on my own and others' experiences with parts on different cars.
It's still a safety issue for a number of reasons, although a less severe one. First, shot bushings substantially increase the momentary loads on other suspension components when there is a transition (such as a braking event or a sharp corner). That could increase the likelihood of something like a control arm or a tie rod failing catastrophically. Second, shot bushings effectively put the car out of alignment (and in different ways on acceleration and braking), giving less accurate steering control and potentially less grip in an emergency situation. Third, this failure on the LS in particular tends to lead to inner-edge tire wear, to the point where members have posted that they had exposed belts on the far inner edges when there was still plenty of tread on most of the tire. That type of wear is hard to see unless you're looking very carefully and may go unnoticed for too long.
fooldall1
Southeast
10-01-16 06:23 PM
