LS460 Door light module? PLS HELP!!
I think my multiplex network door computer went bad also. Where is it located? My bulb is good and my door switch is good but there is only 9v going to the door connector when the door is open and then it actually raises a bit when I push in the door switch. So, there is a constant drain in my battery. What else could cause this? I don’t think it’s a bad ground because I also noticed that the oem bulb assembly plastic has weird discolored residue in it and therefore something must have happened to blow it out or short it in some way?
Here is the location of the multiplex that you are talking about. I blew mine out while installing the led courtesy lights yesterday. Accidentally touched the connection with a screwdriver. When installing LEDs it's better to disconnect the lighting fixture from the wire harness first before installing the bulb. This will save you a lot of headaches on the installation. Hope this helps you or anyone else who reads this forum. Good luck!
Below the tweeter is the module. (Red box) You can buy on ebay used. Ls460 RR door.
GreggyG (03-28-22)
