LED running lights replacement
I noticed that the after market DRL LED I installed a while back like few other on this forums are both broken. Without having been in any crash or bumped against anything the plastic lens cover on both side is falling off.
Is there a better brand to use to replace them and what is the best/safest way to remove the 3M double sided auto adhesise I used to put them on?
LED daytime running lights replacement
Better brands- look at Hella, Phillips...of course more $$$
Goo Gone works well to remove adhesive. You may need to heat it up a little with a blow dryer or heat gun if its a little hard
Yes I bought the same lights. I've bought a couple of extra sets. Like I said, dirt cheap and they look great.
lexusridah
IS - 1st Gen (2001-2005)
12-21-09 12:03 AM
