Need input on these set of 20's rims
They are 20x9.5 front and 20x10.5 back both offset 20
Will anyone here let me know that will they clear both brake and fender on Ls460??? Thanks for any input
Should be ok if you're keeping I stock height. The rear might give you problems if you lower the car. Also depends on the tire size you run. As for brake clearance that can't be said based on width and offset. The face type ultimately will determine that. The LS brakes are pretty thick so not everything will fit.
I think lowered on Tanabe springs shouldn't be problem, depending on tire size. As mentioned above, disk size will determine if it'll fit over the calipers.
I've got a set of 20x9 +16 - 245/35 and 20X10.5 +16 255/35 lowered on tanabe springs. fenders not rolled or shaved. But I think I will need to shave the rears, there is slight contact while entering driveways.
Just measure the inside of the front wheels disk. If its nothing to measure, it wont fit.
