Horn not working
Old 11-07-21, 12:40 AM
  #76
Benjam1n
Benjam1n's Avatar
Finally fixed mine. Took 5 min. This thread delivers. I didn't even disconnect or clean any wires. I just followed the directions and loosened the horn screw connection at the bottom then tightened it down. Great to have the horn back.
Parrokeete (11-07-21)
Old 11-07-21, 06:23 AM
  #77
Parrokeete
Parrokeete's Avatar
Wow, where can I find this horn screw? Mine still blows sometimes. Glad you have that friend and glad your horn is working.
Old 11-07-21, 12:26 PM
  #78
Benjam1n
Benjam1n's Avatar
That's what I called the "horn screw." Phillips head. From the video above.
Old 11-07-21, 12:35 PM
  #79
Parrokeete
Parrokeete's Avatar
Thanks for the video.
Old 02-10-22, 03:21 PM
  #80
1eyedjak
1eyedjak's Avatar
few years later still no horn. I cant believe all that some have done is remove the pad and reconnect some plugs. I need to do that because im selling the car. 2010 es350
Old 02-10-22, 03:22 PM
  #81
derreckla
derreckla's Avatar
Mine is still going strong....
Old 02-10-22, 04:13 PM
  #82
fwhomeboy
fwhomeboy's Avatar
Mine still works once in awhile.
Old 02-10-22, 06:41 PM
  #83
Parrokeete
Parrokeete's Avatar
Originally Posted by Parrokeete
My horn does the same thing. The Toyota dealer wanted to charge $3600 for a new horn sir bag snd a clock spring. I found a clock spring on EBay but my mechanic shop said when they installed the clock spring it caused a lot of warning lights to come on and they replaced the original one. Horn still blows intermittently,
I finally got my horn working like a champ. I saw this video where there is a screw under the air bag you have to unscrew it and clean it and around it then replace it and the horn will work again. Before that I was thinking I needed a new clock spring.
Old 02-11-22, 12:18 PM
  #84
falconx
falconx's Avatar
Mine is also still working, as I posted above I only had to remove the horn's cap and massage the wires, for sure it was a bad contact somewhere but I have been unable to precisely locate which plug was faulty.
Old 02-11-22, 02:48 PM
  #85
fwhomeboy
fwhomeboy's Avatar
I finally got my horn working like a champ. I saw this video where there is a screw under the air bag you have to unscrew it snd clean it and around it then replace it and the horn will work again. Before that I was thinking I needed a new clock spring.
I'm going to do that job next week while I'm off work.
Old 02-12-22, 03:33 AM
  #86
lwphat66
lwphat66's Avatar
Yeah, but what about the horn?
The following 3 users liked this post by lwphat66:
Cape600L (02-12-22), fwhomeboy (02-12-22), miket000 (02-12-22)
Old 02-16-22, 07:13 PM
  #87
1eyedjak
1eyedjak's Avatar
took mine apart tonight . no luck...but I just saw the pic with the screw on the airbag. guess I will try that tomorrow
Old 03-01-22, 04:17 AM
  #88
1eyedjak
1eyedjak's Avatar
took airbag off..there is no screw to unscrew on my 2010 es350 so I am now looking at the clockspring ...this is very aggrivating
Old 03-01-22, 01:36 PM
  #89
fwhomeboy
fwhomeboy's Avatar
Try looking in the ES350 forum first, then try youtube. Good luck Sir.
Old 03-04-23, 10:23 AM
  #90
fwhomeboy
fwhomeboy's Avatar
I finally fixed my horn. Took me 30 minutes. It was the blue wire dirty. Cleaned it and now it's good 👍🏾
Parrokeete (03-05-23)
Quick Reply: Horn not working
