Heated Steering Wheel Light Stays On
I'll definitely do what makes sense. The switch works as far as turning the heat on and off so I may just leave it as I'll never use it and it's probably not worth the hassle. Was hoping for an easy fix though.
I have the exact same problem described here, in a 07 ls460 at 136k miles. I can't say when the issue started as I bought it this way - the switch works to toggle the heater on and off but the light on the switch never goes off. It wasn't clear to me which fuse is the right one to disable it either, does anyone know?
Actually the OP mentions the heater is the same part with the parking assist, and that is fuse 3 on the passenger side so perhaps that'll do it, I'll go see. *pulled fuse* Well the steering wheel heater light stayed on still so I don't think that was it. Not sure how much time I want to spend since it functions fine besides the light always being on.
edit: I should add, in my case the heated steering wheel button light was ALWAYS ON, but the heat was NOT ON unless toggled on, and the button worked correctly other than the light on the switch not toggling.
Thegamemhb (12-05-19)
