Wind Noise on my 2008 LS
#31
I did the install this weekend. It is very easy to do. I was blessed with a package that came in the mail from a kind and generous member. I won't name who in case they want don't want a flood of messages. They sent me the metal pieces. I have had enough time to tell if there was an improvement or not. Today was the first day driving on the highway. I'm think it is better but I don't want to make a determination so quickly.
Thank you again for your help and donation to my cause.
#32
Yeah that mystery jmcraney guy is a pal.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#33
I have an apt with the dealership on Friday. I think I found the problem per your suggestions,
https://www.dropbox.com/s/20igworpqu...22208.jpg?dl=0
https://www.dropbox.com/s/epnjsv67wy...45722.jpg?dl=0
#34
Yep, that's definitely a problem.
#35
It's hard to tell from the picture exactly what has happened. But, it looks like the window gasket will have to be replaced.
#38
You'll probably have to have a dealer or independent replace the rubber gasket that goes around the top and sides of the glass.
#41
They are going to fix the problem for like 300 bucks. The entire Window gasket had to be replaced? They are giving me a discount due to me being in there before for the same type of window / wind noise.
The Tech said he only sees this problem with the drivers side window for the most part.
#42
DId you attempt a fix yourself before resigning it to a dealer? For such a cheap, quick and easy attempt, I would have done that first.....especially since the dealer may not cure the issue you're having to your satisfaction.
#43
Probably because the driver is more likely to identify the issue. If we were driving a British spec'd car, the other side would be identified more as having an issue. Both sides of the car are identical with respect to design.
Atl
01-14-09 06:00 PM
