Vibration at highway speed - are those tread wear normal ?
Since I got my car back from the dealership after changing the rear shock this summer, I can feel a vibration in the car at highway speed. After the shock were replaced the car steering wheel was out of balance and pulling one side. After they attempt to align the car about 5 times it got a little bit better. Then I found out that they had an accident with my car and tried to hide it: https://www.clublexus.com/forums/ls-...on-camera.html
I suspect the tie rod may have been damaged so that could explain the steering issue. It also seems to have gotten worse over time. I'm trying to figure out the possible cause, if directly related to the tie rod damage or indirectly as if the tie rod damage could have caused uneven tire wear and then causing the vibration over time. I've attached some pictures, the 2 first are from the front passenger side, the 2 last from the front driver side. My tire are the Michelin pilot and this thread seems to suggest those tire might be hard to align properly: https://www.clublexus.com/forums/ls-...er-things.html
I'm due for my winter tire change soon and see if thing gets better, I'll get them balanced too. I'll check at the same time for control arms/shock damage. But still, I would like some feedback and see if those tread wear are normal and hopefully get to the root of the problem (the outer edge on the tire in the back are much less damaged).
andy00018
RX - 3rd Gen (2010-2015)
10-31-23 11:34 AM
esowner11
10-03-11 07:20 PM
hmkim
05-25-10 12:50 PM
Maxx941
13
12-29-07 05:29 AM
