Audio source meriting Mark Levinson system
Still hard to believe that people believe that a Music source of a thumb drive or a Bluetooth connection is suitable for an audio system like the Mark Levinson option
I treasure the hard drive in my 2009 Mark Levinson system which was eliminated in the 2010 model year. The other luxury brands recognize the value of a built-in hard drive taking music from a CD without losing fidelity
Thumb drive is just fine if your files are encoded decently. Lossless, or MP3/AAC above about 256 kbps, are good enough on almost any type of music. At that level or above no one has shown the ability to choose the uncompressed source consistently in blind tests, except for certain music with very complex waveforms.
I play my music through my iPhone. It's encoded 256kbps AAC and sounds terrific. The only place I can tell the difference between 256kbps AAC and the original digital source on my home system is in harpsichord music.
You are wrong, the music get compressed when it get copied to the car HD in the 2007-2009 car and in a pretty ****ty format too (WMA). Personally I can notice immediately the loss of quality when it's ripped on the HD even at 256kb. Some mp3 from a thumb drive will sound much better than this. The best option is either CD, Audio DVD (best option IMO as you can fit much more uncompressed music than a CD and you can up the sampling rate), or lossless format like FLAC from a phone/pc stick hooked through the HDMI port of a ivic setup. Wifi streaming in some case wont compress audio (if you stream for example a flac file) so it's much better than bluethooth as a wireless solution.
Thanks. I never knew that but everything sounds better on the ML. That's one of the reason I had to go back to a LS460 from a LS430. I loved the sound system balance.
wmogolov
ES - 7th Gen (2019-present)
30
12-15-19 03:03 PM
Jagstyles
05-18-15 04:36 PM
I8ABMR
10-07-12 03:08 PM
