BC Coilover install
Old 12-29-15, 05:09 PM
Bluv
Bluv's Avatar
Default BC Coilover install
How easy/hard is the install For 07 LS 460, I wanted to tackle this project over the weekend & was wondering is there a diy with pics any help appreciated & thanks in advance
Old 12-29-15, 07:22 PM
Steflex
Steflex's Avatar
I was going to ask if you searched yet but I tried to search myself and I did not find a step by step guide. Can anyone else chime in?
Old 12-29-15, 07:52 PM
Bluv
Bluv's Avatar
Yea, I've done the search thing
Old 12-29-15, 08:16 PM
is150
is150's Avatar
Check out the new thread titled "I did my own control arms" that was posted today. It will detail one of the steps on how to loosen the upper control arms to gain access to the front struts. I consider that the hardest part of taking the front shocks/struts out. When removing the front shock and installing the new coilovers make sure that the front of the car is jacked up (both passanger and driver side) or else there will be to much tension on the sway bar.
As for the rear the hardest part of the install was dealing with the back seat. Here is a thread to help you with removing the back seat. https://www.clublexus.com/forums/ls-...t-removal.html
Check out the youtube videos of the coilover install on the GS430 and AWD is250/350
Old 12-29-15, 08:35 PM
Doublebase
Doublebase's Avatar
I'd probably remove the lower rearward facing control arm, and slip the strut out the bottom. There's just not a lot of room to get that strut out without removing that. I could be wrong - and maybe someone else has pulled those struts down hard enough to clear the fenders - but I wasn't able to do that today. As for the top, just remove the three 14mm nuts at the strut tower.
Old 01-01-16, 06:56 AM
Bluv
Bluv's Avatar
new year bump
Old 01-02-16, 01:43 PM
Steflex
Steflex's Avatar
new year bump
Since there is no Step by step guide, I will document the install of my coilovers. I got BC's with the swift spring upgrade so should be right up your and others alley. I am planning to have the install done next week Friday.
Old 01-03-16, 06:24 AM
Bluv
Bluv's Avatar
Thanks Steflex greatly appreciated
Old 01-11-16, 04:33 PM
Steflex
Steflex's Avatar
Bluv,
I let you down brother, I let my installer do all the work and didn't take many pics.
The ones I took are posted in a Steflex build thread in the LS section.
Tips I can say:
- make sure you preset the preload to 4-5mm
- get the damping extenders for the rear and sneak them through the child safety seat latches
- do a search on how to remove our rear seats ahead of time
I hope that info was at least helpful.
Ls460kidd
10-31-17 01:23 PM
LamTheSham
Suspension and Brakes
07-05-11 10:29 PM
GX470GT
05-17-11 08:30 AM
DanIS250
01-03-11 07:47 PM
ES EF ED
11-16-08 07:42 AM
Quick Reply: BC Coilover install
