Radiator Replacement
#31
I would also like to know this as well! I forgot to add some fresh fluid after changing the rad, .5 quarts?
#32
Please follow Lexus procedure of monitoring temperature with software when checking and/or adding trans fluid. If you have over 75k miles, it's a perfect opportunity to do a drain and fill maintenance.
#33
A few months later I changed the tranny filter and serviced it correctly.
#34
That's some terrific forethought. From other threads, I understand that even 1/2 qt low can cause trans issues.
saephanh12
03-26-14 08:53 PM
