Does anyone know if there's a way to disable the initial start up screen on a 2013+ that tells you "Drive safely and obey traffic rules....." then has a "continue" button to select?
Hmm. Mine come up then continue on by itself. On my SC430, it won't go on unless I hit accept or agreed to continue on. That's annoying. Hope someone can chime in.
Oh yes to clarify you can select it but if you don't it will advance, I'd just rather have my custom image stay on there than an annoying disclaimer. I get it, I drive it all the time, I'll be careful.
On your SC430 it is because you have an old version of the nav software. I think since about 2009 updated versions of the software discontinued the need to push the "I Agree" button. This is the case for the LS, but your system may be different. You might want to do a search in the SC forum.
I'm not sure you can disable the screen. I'm just glad mine goes away by itself instead of my old 430 where I had to press the agree or continue button every time.
I did and knew that. Thought the OP had the same problem, that was why I stated that. I'll tear out the whole system out and replace with new aftermarket equipments. The Mark Levinson is good but it's a 12 year old system. It's time to let it retire.
