SSD via the USB port?
Old 02-10-16 | 03:49 PM
Scrutator's Avatar
Scrutator
CarGuy89: I'm using the 128GB Ultra Fit and after re-evaluating it, it may do for a while. I have some 1500 CDs but I'm not certain that I'll transfer them all.
Old 02-10-16 | 03:56 PM
CarGuy89's Avatar
CarGuy89
Lol I gotcha. Yeah the SSD question is in my mind too, but it's more for the internal HDD that's built into the car (looks very difficult with $$$ software). The issue with running an ext SSD harddrive would be the power source, which you would have to get a cigarette plus to outlet converter and I can only assume that's just quite bulky. In my experience with ext drives the ones without a power source are weak and tend to be unreliable.
As far as the speed factor goes, I'm not sure that you will see any benefit with more speed esp since you are playing back a file rather than performing constant file transfers. I think your current solution is probably the best.
I can't believe cars of this age still use HDD lol I worry about this esp since I am in MI with not only cold weather, but horrible roads. Both those have to be hell on a conventional spinning disk!
Old 02-10-16 | 04:53 PM
Dryrunner's Avatar
Dryrunner
Scrutator,
Where is Ca are you. Love to trade albums for my 600 movies
Old 02-10-16 | 05:27 PM
Scrutator's Avatar
Scrutator
Dryrunner: 600 movies?(!) I doubt I've seen that many in my life. I also doubt that you've heard of most of what I have, which is modern jazz. Here's a sample: Xploding Pastix; Pat Metheny Group; Garag Mahal; Ozric Tentacles; Eivind Aarset; Cantoma; Four80East; Nils Petter Molvaer. Oh, and yes, I have a Pink Floyd disc or two.
Old 02-10-16 | 05:55 PM
Dr. Jekyll's Avatar
Dr. Jekyll
Originally Posted by scrutator
dryrunner: 600 movies?(!) i doubt i've seen that many in my life. I also doubt that you've heard of most of what i have, which is modern jazz. Here's a sample: Xploding pastix; pat metheny group; garag mahal; ozric tentacles; eivind aarset; cantoma; four80east; nils petter molvaer. Oh, and yes, i have a pink floyd disc or two.
no no no no no no no no no yes
Old 02-10-16 | 06:50 PM
R Z's Avatar
R Z
Love Metheney. Had the pleasure to see him in concert. Fantastic.
Old 02-11-16 | 05:28 AM
Vansibel's Avatar
Vansibel
I've done it with a 2TB hard drive on the usb of a subaru, it should be exactly the same for the lexus as far as you are using the oem usb input. First you need to get a Y usb cable in order to separate the power signal from data or else your drive might not work of it will be very unstable: http://www.ebay.ca/itm/USB-2-0-A-to-...YAAOSwFnFV8MmY
Then you plug one usb (need to be the one with the power signal - just switch end if it's not working) into a power adapter outlet for car (plug one into the socket just next to the usb) and the other end into the usb of the car. But first and this is very important, you need to format your drive using a special tool to break Fat32 32gb barrier (never tried other format on the lexus but usually those device like tv usb and car only support fat32): http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
Although it was working flawlessly there was so much music available that it became hard to navigate because the media browsing front end of the car wasn't designed to handle so much music (Ex: sometime I had to press down for a very long time to reach an album).
Old 02-11-16 | 11:26 AM
Scrutator's Avatar
Scrutator
Thanks, Vansibel! Excellent solution. Fortunately, my 2013 LS has voice commands that allow me to speak the artist or album so it minimizes the need for protracted searching.
Old 02-11-16 | 11:40 AM
Dr. Jekyll's Avatar
Dr. Jekyll
Tell me the trick, I can't get the voice recognition to find anything on my iPod!
Old 02-11-16 | 11:44 AM
Scrutator's Avatar
Scrutator
Can't speak for the iPod; it works perfectly using music stored on the USB drive. When you select your voice-command button does the option to play an album or artist show on the screen?
Old 02-11-16 | 11:49 AM
Dr. Jekyll's Avatar
Dr. Jekyll
Yeah, then I get the command not recognized
Old 02-11-16 | 12:16 PM
Scrutator's Avatar
Scrutator
Maybe there's some type of setting that allows the iPod to be seen as a drive rather than a device with its own operating system?
JSracer
RX - 4th Gen (2016-2022)
10-14-18 07:09 AM
shenry500
09-13-18 08:21 PM
tolick
ES - 6th Gen (2013-2018)
02-19-14 09:13 AM
Wolffe72
RX - 3rd Gen (2010-2015)
09-11-11 12:04 PM
jg 368 48
RX - 1st Gen (1999-2003)
05-08-07 08:54 PM
Quick Reply: SSD via the USB port?
