Anyone replace Hydrocarbon Switching valve for LS 600hl
#61
I wonder what percentage of ls600 owners use club lexus? My dealer said mine is the 2nd 600 to need this replaced. I wish i had seen the post earlier that it has passed emissions. I would probably not have had it fixed at all! Especially that I don't use the car.. makes no difference.. to have a message..
#62
#63
Originally Posted by DMVLS600HL
I am having the same issue with my LS. The dealer wants to replace the entire exhaust pipe. The part that needs to be replaced in inside the exhaust and can not be removed is what I'm being told and the exhaust pipe isn't sold in parts. I've been desperately searching for a work around but so far no luck. I've spoken with a far mechanics and they are telling me the same thing. Lexus also turned me down for financial help with the repair. They said something about my maintenance record. I'd been taking my vehicle to them for everything. Now that I've run into this problem I'll be doing my own maintenance from this point forward. I'm currently trying to find a used exhause from a salvaged car. If I figure it out, I'll post my results.
#65
As my employee picked up the car and was driving back, the engine light came on again!
I was not convinced that the hydrocarbon switch needed replacement. I told them to double check and they said that they did.
We sent the car back..
I am still not convinced that the hydrocarbon switch needs replacement. The service guy sees a diagnostic code and reacts to that.. I don't know if there is any other way to check whether it failed.
Since I know them well enough, I know that they won't knowingly cheat me..
#66
#68
mileage on mine is 90k
today the dealer said they had three codes. two for the hydrocarbon switch and one for the exhaust gas temperature.
Now, he says he is replacing the exhaust gas temperature switch.. $800
#70
Who said that the exhaust gas temperature switch is not the reason for the three codes and there was no reason to replace the hydrocarbon switch??
#71
#74
Seems like this is the same problem I had, except your is on bank 1.
Mine: P1083 LEXUS - HC (Hydrocarbon) Absorber Switching Valve Bank 2 Stuck Open
Yours: P1081 LEXUS - HC (Hydrocarbon) Absorber Switching Valve Bank 1 Stuck Open
Possible causes
- Faulty Exhaust Gas Temperature Sensor
- Exhaust Gas Temperature Sensor harness is open or shorted
- Exhaust Gas Temperature Sensor circuit poor electrical connection
- Hydro-Carbon Absorber and Catalyst (HCAC) valve stuck or actuator problem
Mine: P0549 Exhaust Gas Temperature (EGT) Sensor Circuit High
Code P0548 is a similar code which states that the circuit shows "low" voltage. Both relate to the condition of the sensor and the correction is the same for both. This P0549 DTC refers to Bank #2 (which is the side of the engine that does not contains cylinder #1). The DTC P0546 is basically identical, however it is for bank 1.
Seems like this problem is not isolated if your dealer had 2 additional cases. For me replacing the exhaust gas temperature sensor (1300$ can) solved the problem.
Possible causes
#75
If your dealer replaced the valve (or the whole exhaust as they did) and the problem turn out to be the sensor, they made a very poor (or lazy) diagnostic because I think it's possible using techstream to monitor the voltage going into the sensor, or using a simple Voltmeter.
