This sounds like a problem?
Still in the market looking for a 2010+, found one that might work but have this in the recent service record. The previous owner sold the car just a couple of months after this item was serviced in a dealership.
"INSPECT FOR FLUID LEAKS CS THERE IS A BROWN FLUID LEAKING UNDER VEHICLE ADVISE - FOUND OIL FILTER HOUSING DRAIN BOLT SEALED TO BE ROLLED & PINCHED CAUSING OIL DRIP -
REMOVED OIL FILTER HOUSING BOLT, REPLACED SEAL, AND TORQUED TO PROPER SPEC. ADJUSTED FLUID LEVEL & VERIFIED NO LEAKS"
Is this going to cause problem in the future? much appreciated~!
I kind of doubt it unless the thing had been driven four quarts low for 1000 miles. It's a common problem for the o-ring gasket on the housing to get rolled and drip...at least the customer cared enough to bring it in to get it checked out.
