Multiple Battery Replacements
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
The LS460 is an electrical hog on the battery, all the electrical systems wear down that battery if your just going 3 mile short drives. Your car requires a certain load to start that car, and in the short few minutes of use, you have not enough charge time from the alternator to offset the start load. Do this about 3-4 times a day, and your battery is not going to survive more than 18 months. Do a couple long drives per month, and this should easily double your battery life. Remember that car batteries like to be used and then properly recharged. The longer drives successfully extend battery life.
I think the best bet is to buy a battery with a good warranty and from a place that will actually warranty it. That way you'll get it replaced for free or have it prorated. And the testing of the battery is also crucial...these hand held testers used to test a battery today go very easy on the battery, you'll get a lot of false passes with them. However if a carbon pile tester is used, those questionable batteries will fail the very same test that the handheld testers, passed.
I think if you're getting five years out of these batteries you're probably living in a warmer climate, you probably don't start the car multiple times a day and you're not using your automatic trunk feature all that much.
I'm facing the same issue right now.
Yesterday the car didn't want to start. Last week as well. I have to jump,it with my Lincoln.
Both cars get driven few times a month. I'll take it back to,autozone as their last battery lasted only 2 month. Let's see if this one is defective as well.
I even let the car idle for an hour once a week to keep juices flowing.
pman6
05-18-15 01:49 PM
