Brake actuator service bulletin
#181
#183
I have a 2011 LS460 with 86k miles. Can I still get the replacement through bulletin?
#184
Yesterday, I heard a loud pop when pulling out my driveway and now as I brake the car vibrates. Local Lexus dealer said that its just rust on the rotors. They said no codes generated in TIS and that they cannot fix the actuator since it seems to be functioning properly. They advised new rotors and brakes would fix the problem. I scoffed at that saying i just had a service A done 2 months ago and was never told about any rust where it shows they were inspected and I had the rotors resuraced and pads changed on both front and back 1.5 years ago at 44k miles and the car now has 55k miles.
I think they are just trying to avoid fixing the Actuator before extended warranty ends this month.
Suggestions? opinions?
2013 Lexus ls base AWD
#185
#186
#187
If you park outside and don't drive often then you probably had some surface rust that flashed over the rotors. The "pop" you described is usualy exactly what it sounds like then the rotors get moving again
#188
Is it really necessary to get all new brakes and rotors ? Brakes still have 8mm om them
#189
These cars are known for not so great factory rotors so just be aware of that
