LS 460 Rear Coil over shocks
I've changed mine out multiple times. What are you asking though? Coilover shocks? Are you lowering your car? are you replacing the rear shock alone?
what trim package do you have?
Looking to change out OEM coil over shocks with KBR shocks as one of mine is leaking oil. Does one have to remove most suspension component as Toyota procedures. Or just remove stabilizer and undo the one control arm?
Any procedure or info from your experience would be much appreciated.
2007 LS 460
Thank you
2007 LS 460
Thank you
