Cabin Air Filter
#34
I bought a Fram Fresh Breeze with arm and hammer, at Walmart. 12 bucks. They had a ton of them in stock on the shelves.
#35
I picked up a couple of DENSO 4531019 from Rock Auto for $7.46 a pop. Denso supply a lot of parts to Lexus and maybe these filters. That's the name on the cabin filter frame.
#36
Jud149
That is the one of the correct numbers for the Denso cabin filters that fit the LS. That is one and it is not a carbon filter but it should fit. The others are the 87139-50100, which is a carbon filter and 8713907010 and 8739052020 which are not carbon.
Dennis
Dennis
#37
[QUOTE=DJWLDW;9599508]Jud149
Dennis[/QUOTE
Thanks Dennis. This is what Rock Auto's description says about this filter for the 460:
"DENSO is the OE supplier for this vehicle; Premium particulate filtration media; Captures pollen, dust, and other allergens"
Frankly, however, I not convinced about the value of this filter, let alone the charcoal, and especially replacing it every year. I just checked my car's current filter which has been in for 3 years and it looks brand new and I live in FL where the a/c is continuously cranking, mostly on higher fan speeds. Also, I have friends in the residential/commercial a/c business and they all recommend using the base filter for homes, etc., saying the premium type is a waste of $ unless you have pets and/or children with allergies. Just my 2 cents...
Dennis[/QUOTE
#38
jud149
I got my last one from rockauto as well. I went with the TYC 80010BC which is the knock off of the 87139-50100 carbon filter. My wife has bad allergies and anything that helps is worth the extra couple of bucks.
Dennis
Dennis
#39
Makes sense to me. AND THANKS FOR SERVING! YOU DA MAN!
#40
[QUOTE=jud149;9599738]
My filter looked pretty damn clean as well after a year, I replaced it anyway, it was only 12 bucks, but I understand what you're saying.
My engine air filters also looked remarkably clean after a year and 29,000 miles of driving. And the thing is I was worried about them...figured I had let them go too long...the package said to replace them every 12,000 miles. So I figured they'd look terrible when I changed them, instead they looked so good that I felt funny throwing them away. And where I live the pollen in the spring is so bad that my car turns green for about a month. It's so bad that you can actually see it blowing right through the air. And in the winter I drive on a lot of salted roads...the stuff is everywhere...it's all over the car, you can see it hit the windshield. I figured the filter would look nasty, it looked almost brand new, but I changed them anyway...they're only $12 bucks a piece.
Jud149
Dennis[/QUOTE
Dennis[/QUOTE
ToyotaLexus
RX - 1st Gen (1999-2003)
10-19-08 07:03 PM
