Waze Integration into Navigation
Hi all,
Thank you for your interest in VLine Lexus Infotainment System upgrade by GROM Audio. To answer to a few questions that arouse here:
1. The compatibility of the VLine will be expanding to include other Lexus and Toyota models and production years. The presale is for the models/years that are already supported. We are working on adding more.
2. VLine is a stand alone unit that connects to the back of your stereo and uses touchscreen in your car. You do not need the phone to use VLine, except for the WiFi tethering. You can also stream the music with A2DP Bluetooth streaming from any Bluetooth capable phone.
As it is Android based you have the access to Google Play apps.
3. Apple integration (aka Car Play) is pending, however if you have an iPhone you still can use VLine.
The VLine does not affect any other functions of your vehicle - CD, FM, factory Bluetooth, backup camera - etc...
Thanks again, we are happy to answer any questions you may have!
Hi all,
1) When do you expect to support 2013+ model years?
2) Can your unit also bypass the nav system to play DVDs on the Nav screen when the car is in motion (like the VAIStech ULM71 system)?
In fact, the Beatsonic unit (NDS6223EP; $240) and installation described by CharlesCA above will enable Nav DVD bypass as well as mirror an iPhone. It looks very promising. The original installation instructions are from 2011, and Charles has done it in 2016, so maybe the Beatsonic unit has not changed much. I am not keen on trying this out, but I would be willing to consider it if an intrepid 2013+ LS owner has a good experience with this mod.
Hi all,
1. We will be working on it mid September. No ETA yet, but we will keep you posted.
2. No, the only way to play video is through Vline interface. There will be a legal disclaimer on that though.
Thank you!
http://www.beatsonicusa.com/if04ep.html
