LS460 weak suspension on bumpy road
Old 09-30-16, 07:13 PM
  #61
2v1g
2v1g's Avatar
I got a chance to look at my leaking rear struts today when I installed my new pirelli tires. They are kind of seeping liquid
Old 09-30-16, 07:48 PM
  #62
droclex
droclex's Avatar
Depending on how long it's been leaking, it might explain why your front end feels a bit less stable than you think it should.. Another member is in the process of looking for affordable shock replacements. Might be a helpful reference:
https://www.clublexus.com/forums/ls-...ew-shocks.html
Good luck to you!
Old 09-30-16, 07:51 PM
  #63
2v1g
2v1g's Avatar
I am lucky I am covered by ECP. Don't know how much if you need to pay yourself?
Old 10-02-16, 08:39 AM
  #64
Vicqlo
Vicqlo's Avatar
I experienced a similar issue with my 2011 AWD. Dealer found broken coil spring on left front. Both front coil springs replaced and tire pressure reduced to 33 psi. Car rides much better now.
Old 10-02-16, 06:40 PM
  #65
2v1g
2v1g's Avatar
I am very picky. I just installed the new pirreli tires., dealer is ordering new pair for seeping rear struts. If that does't solve the issue, I will ask dealer to recheck the front suspension. With extended warranty, I will make sure my suspension works perfect
Old 11-18-16, 05:59 PM
  #66
2v1g
2v1g's Avatar
After replacing the 2 seeping rear struts, don't feel car lands on bare rim anymore when going over the bumps. The suspension is still not as solid as my Previous 430, but overall pretty good. I guess that is the character of the regular suspension on 460
Old 11-18-16, 07:32 PM
  #67
Received 2,730 Likes on 1,956 Posts
Are you certain there isn't anything going on with the front struts?
What PSI are you running still?
Old 12-01-16, 09:01 PM
  #68
2v1g
2v1g's Avatar
After the new Pirelli tires and new rear struts, it is better, but they are still little bit weak at the rear, can it be spring or control arms?
Old 06-10-19, 01:26 PM
  #69
2v1g
2v1g's Avatar
Sorry to update the fix for the issue so late. It turned out to be the sway bar. The car makes no noise after the sway bar is replaced.
Tantrix
05-28-20 06:12 AM
bsl888
12-26-19 10:20 AM
sparky3
03-11-15 12:56 PM
charley240
Lighting
24
04-06-10 03:39 PM
Threxx
10-30-06 09:46 AM
Quick Reply: LS460 weak suspension on bumpy road
