Brake Pad and Rotor Thread
#106
From 2013-2017, the RWD and AWD NON F Sport models use the same rotors and brake pads. Hope this helps.
__________________
Kevin- Sales Representative
R1 Concepts Inc.- Performance Brake Parts
Kevin@r1concepts.com
888-712-6623 Ext. 7022
#107
I have my window sticker and I don't see "Touring Package". This car has everything else so I'm surprised I don't see "Touring Package". I'm ordering new brake rotors so I want to be sure I get the right kind. Is "Touring Package" what should be on the window sticker? What features/parts are in the touring package?
#108
For a 2014 F Sport RWD how many brake sensors are needed? 2? 4? If they have not been activated can i simply reuse them or should I be changing them every brake change like with my old BMW?
#109
#110
#111
Was meaning to bump this...
I'm at almost 7,000 miles on my 2017 now, and my OEM rotors are smooth and un-warped! I'm amazed, I've done some mountain trips too loaded down and no warping at all. My 2015 rotors were warped bad by now. I wonder if they made some changes to the parts?
#112
My 2010 LS600hL is still going strong on the original OEM brakes after 66k miles (from reviewing the Lexus service history). The last checkup was last year at 60k miles, and the note said the pads were down to half of their life. I do get a slight amount of pulse when braking, but not enough to make me want to change brakes and rotors just yet. I know that the hybrid regenerative brakes on the LS600hL last a lot longer than the standard LS460 OEM brakes. I'll probably have mine changed with OEM parts sometime in the next year or two.
#113
That doesn't surprise me so much because of the regenerative brakes...
#114
#115
Former Sponsor
I agree. Good question. Pay more, for (what I believe to be) lower quality? When I took possession of my 2010 (in late 2014), it had 13,800 miles on it. The front rotors were warped horribly.
I removed them and had each one resurfaced for $10 each. My car has like 41k miles on it now and the warp has been returning since about 40k. To me, this is unacceptable for an $80k+ (originally) flagship. This warp annoys the living ---- out of me. And I baby the car, I don't drive or brake hard. I'll deal with it when I have time, by following this thread's recommendations.
Steve - in Toyota's defense, and in my experience with working as a design engineer for them. When they KNOW of a problem, they focus all their effort to determine the absolute optimal resolution, and then execute. I wouldn't put it past them to have made a change to the brakes. Maybe it took a long time because *maybe* they studied the issue and determine for them to change the rotors alone, was not the optimal solution. Or it could be that based on their criteria to filter out what is a real problem, the brakes didn't get recognized as a worthy concern until later in the game.
I have big time respect for Toyota from having worked for those guys. And then gained MUCH MORE respect for Toyota, when I went to work for Hyundai-Kia. My complaint stems from the fact that the LS is the flagship. A flagship should be big, bold, boastful, and have excessive unnecessary stuff (like 8 cylinders when 6 cylinder may get the job done). As far as cylinders go, to me the right approach to a flagship engine would have been to add a cute little supercharger to the 5.0L V8, or even to the 4.6L V8, and throw that power in the face of their competitors. Not to downsize. This isn't a Corolla, where downsizing makes sense. And, if I make it to 80 years old, I'll want a car that sounds pleasant (not silent) when toodling along, and when I slam the throttle to the floor, I want the car to do a back flip from all the power, and sound like a racecar at full throttle.
Anywho, I digress. Back to the brakes. The brakes should be the size and durability of what is seen on Mack trucks and freight trains, for a flagship.
#118
I recently purchased Centric rotors and pads (posi-quiet ceramic) from Rockauto and had them installed at an independent shop. I have been happy with the Centric's over the stock that was previously on the car. The pulsating was unbearable and the car only had 19k miles on it!!!
My only complaint on the Centric's is that I have a terrible squeak the very first time I press the brake pedal each morning. No noises after that very first time touching the brakes. Not sure why they squeak on the first press of the brakes, but they are smooth and silent the rest of the day, until next morning. Wish I could get rid of that initial daily squeak, its embarrassing......
#119
#120
Did you replace the hardware as well? By that I mean, ALL the springs, caliper slides, retainers etc? As seen here: https://www.dormanproducts.com/p-72341-hw13543.aspx
I don't think anything else was replaced. Should other parts have been replaced as well?
