Side Skirts Removal and Replacment
Just got the car. Damaged the passenger side skirt. A replacement is available on ebay. Does anyone have instructions on how to remove and replace the side skirt?
Thanks
Glenn
Thanks
Glenn
Can you be more specific? I can give you the details, but I need to exactly which part you mean. Are you referring to the sill?
Does this picture help. May be called rocker panel. Not sure. It is the panel below the trim.
Attachment 401210
Attachment 401210
side skirts removal
2. After rubber seal removed. You should see couple screws, remove it all. I think there are 3. Front, middle and rear.
3. Remove all clips under the side skirt
4. Remove front and rear bolts that around the radius fender that attached to the side skirt.
5. Pull out the side skirt starting from the front left to right side. All there is 11 or 12 plastic clips that attached to the side skirt.
I hope this helps.
gwsc (12-26-16)
neilvosko
01-21-18 09:18 PM
