Hi All again. I have yet another issue. I lower my LS460 and now I have negative camber. I look through most of the thread but could not find any information nor parts. Can someone help point me the direction where I can get a set of camber kits. Thanks
OK so I call up Central Pine USA spoke to Sam and sent him a request quote. Called back today no answer. So after all the research n run around I did something stupid. So please if you are in my shoes n was thinking what I'm thinking don't do it. So here's the scoop, b4 I bought my LS460 I had an 03' M3. The M3 front struts mounting comes with slotted holes straight from the factory. So I had the advantage of adjusting my front camber without camber kit. In all of my frustrations I figured if I slotted my front mounting holes on my LS460 it might work. Well sadly it didn't work. Took it back to the alignment shop n got the same #s. So here I am back to square 1. ...
Our front upper arm for the LS460 has an adjustment range from -30mm to 0mm from the factory position. The upper arm also has has a specially designed ball joint which requires our special type short knuckle or we can process the OEM knuckle with our dedicated sleeve to mount the upper arm. The Price of the upper arm is $1500 USD plus shipping, to process your OEM knuckle to mount the upper arm is $800 plus shipping if you send us your knuckles, or + $338 for a new set from Lexus.
Any other questions regarding our products please feel free to ask or send me a PM thanks, Sam
