Location of the turn indicator flasher?
Old 01-13-17, 04:06 AM
mckellyb
mckellyb's Avatar
Default Location of the turn indicator flasher?
I've looked online, but nothing. I figure it's under the dash, driver's side, but I cannot find it. I need to put in a new flasher for the LED indicators.
Said flasher has a **** on it to adjust speed of the flash. That's pretty slick.
Old 01-13-17, 08:03 AM
roadfrog
roadfrog's Avatar
The flasher is located near the firewall behind the center console. It's truly buried and you'll have fun trying to get at it.
mckellyb (01-13-17)
Old 01-13-17, 08:26 AM
mckellyb
mckellyb's Avatar
Oh, man...brutal!!!!
I guess with five fuse panels, putting this on one of them would be kind of foolish.
Old 01-13-17, 04:27 PM
lieup
lieup's Avatar
The flasher turn signal relay is located behind the instrument cluster after you removed it. It was a pain for me just to release the relay harness clip after the cluster removed. After, I removed the cluster and loosen the white plastic that hold the flasher in place and pushes the relay down and remove it from the bottom where the pedals located. Keep in mind that the after market relay will require little slot cutting in order to fit into the oem harness. You will see the different after you removed the oem relay and compare to the after market flasher relay. Good luck and yes it was a brutal just unclip the relay.
mckellyb (01-13-17)
Old 12-12-17, 01:16 PM
DeeBrown
DeeBrown's Avatar
Instruments cluster as to be removed? Any pictures or diagram available... I can't find nothing about the flasher relay...need to replace for my led conversion
Old 12-14-17, 05:47 AM
mckellyb
mckellyb's Avatar
There's a detailed write-up of it here, somewhere.
Found it.
I got to the fifth clip on dash trim and decided incandescent bulbs were just fine.
https://www.clublexus.com/forums/ls-...d-removal.html
Old 08-25-19, 09:03 AM
ma61
ma61's Avatar
Found it.
This is not needed.
Only the plastic bezel around the cluster needs to be removed, just be careful not to scratch up your dash when taking it out!
Old 08-01-21, 01:58 PM
BlackReef
BlackReef's Avatar
Originally Posted by ma61
This is not needed.
So only the plastic bezel, not the entire dash like in the write-up?
peasodos
10-01-18 10:23 PM
jjmaxx81
07-03-16 03:30 PM
Vibes63
06-10-13 09:05 PM
t66sc3
SC- 1st Gen (1992-2000)
03-09-11 11:28 AM
Luv Da Lex
06-30-06 12:03 AM
Quick Reply: Location of the turn indicator flasher?
