Underbody plastic
Underbody plastic
Anyone know what the underbody cladding, y'know, the slabs of plastic which smooth the airflow underneath the car might be called by car-part.com?
I had part of a hay bale, moved to the middle of a dark street, catch what I found was a previously broken part of a much larger piece which had been zip-tied back in-place by a previous owner.
Well, this time it split, ripped out a screw, and I'd like to put it right. I think there are fuel lines it covers, but I wasn't eager to make the damage any worse.
I don't know if this helps, but you have to search on the diagrams for the underbody panels on a Lexus OEM parts site. Here's one link. It refers to a floor pan panel, I doubt it is the one you are looking for, but you could start here and explore. Good luck!
http://www.lexussouthatlantaparts.co...832550020.html
mckellyb (01-29-17)
mckellyb (01-30-17)
Well, it's a piece similar to that, yes, but it's not a 'splash shield', per se.
Thanks for the help, my search continues. I've found my newly zip-tied piece doesn't drag on the ground, pretty much regardless, so I'm good...until something else smacks it.
edit: Aaaaah, HA!!!! Close. Very, very close.
http://www.ebay.com/itm/2007-2008-20...VVunVi&vxp=mtr
I know why this one panel is so difficult to find...only the LWB cars have it. It's a small filler panel between the two large ones which normally attach to each other, on the SWB car. It's a challenge to find on parts diagrams, honestly.
spider165
06-26-24 12:09 PM
pman6
06-16-17 07:30 PM
jonathanrn
RX - 1st Gen (1999-2003)
07-17-15 08:34 PM
shinbo
07-03-14 10:17 AM
