Specs of the wheels?
On the first image it looks like the wheel is 20x9. So the wheel is 9" wide. The second picture I'm unable to clearly make out since it's a bit blurry but it looks like it's either 20x8 or 20x9 as well.
I don't see any offset information unfortunately. The offset is typically labeled as ET xx
Just buy my wheels in my picture albums :-)
Did you try to test fit? I found that using "rimsntires" tire size calculator helps out a lot... you're able to detail out offset, backspacing, etc.
I think it'll be helpful for you.
The_Hitman
Wheels, Tires & Brakes Forum
02-03-05 01:07 AM
