both side of my foglights wont light up.
I looks at the fuse it blows, but then i changed it and it still wont light up..
Does anyone know what is going on?
Depends. Did the replacement fuse blow as well? A fuse usually blows for a reason....short, etc. Look at the fuse again, if its blown, you have a problem. If it's still good, you need to check your relays.
Yes it blown 3 times. Should i just replace the whole HID kit?
Replaced my 6000k garax to morimoto 5500k. Low beam. Please give some feedback on which output light better Left is garax 6000k and right is 5500k moritomo Left 5500k morimoto vs 2013 gs350 stock low beam
