2014 LS460 TSBs
Old 03-06-17, 04:27 PM
sktn77a
sktn77a's Avatar
Default 2014 LS460 TSBs
Does anybody have a listing of the TSBs issued for the 2014 LS460? LexusTSBs.com use to have this information on all Lexus vehicles but the site has mysteriously "disappeared"!
Old 03-06-17, 05:17 PM
Gbp
Gbp's Avatar
I created a thread on how to look up LS460 TSBs:
https://www.clublexus.com/forums/ls-...00h-tsb-s.html
It should work for 2014. I can't vouch for the accuracy of the data, of course.
Old 03-06-17, 06:23 PM
sktn77a
sktn77a's Avatar
Thanks GBP. I tried the link and it worked up to a point. It does list the TSBs but when you click on them, nothing happens (the actual TSB details are not available). Do you know if these are available anywhere without paying a subscription (eg AllData)
Old 03-06-17, 07:51 PM
Gbp
Gbp's Avatar
I think other sites require a subscription for the TSB details. It's odd. Some TSB's show the bulletin for me; others just give a blank screen,
http://www.revbase.com/BBBMotor/Tsb/Results?Year=2014&Make=75&Model=5862&
Old 03-07-17, 03:44 AM
Johnhw2
Johnhw2's Avatar
I have same year in a long WB and with AWD. So interested in what you learn and where you find access to TSB's.
Old 03-07-17, 07:09 AM
sktn77a
sktn77a's Avatar
Found it. It's on the NHTSA website. Takes a bit of juggling around the site to find it. Input the make, model and year and go to "manufacturer communications". Go to the TSB in question and open it, ignore any "summary to be provided at a future date" statements, and go to "associated documents" and there it is.
https://www.nhtsa.gov/recalls#vehicle
The following 2 users liked this post by sktn77a:
comotiger (03-07-17), FatherTo1 (03-07-17)
Old 03-07-17, 08:02 AM
comotiger
comotiger's Avatar
Thanks, Keith. The NHTSA link is informative. I haven't looked thru all the 2014 LS TSBs, but have you found any that concern you? The three I have checked so far have to do with pre-delivery service. Thanks for sharing any further insights.
Old 03-07-17, 04:19 PM
sktn77a
sktn77a's Avatar
I wanted to check on L-SB-0103-14 - whine from the transmission at low speeds. Sounds like a drive train alignment problem as they replace mounts and crossbars to correct it.
Old 03-07-17, 04:34 PM
FatherTo1
FatherTo1's Avatar
How bad is the whine on yours, sktn? I recently test drove a 2013 and in my notes I jotted down a very faint whine when just starting off and when letting off the gas (under 15 MPH). Later in the day I thought the noise was more like an induction whistle, but perhaps it truly was drivetrain whine. Thanks for finding the links and sharing! My apologies if the TSB only applies to 2014, I haven't had a chance to look through anything specific to 2013 yet. Am curious how you would describe your whine.
Old 03-07-17, 05:03 PM
comotiger
comotiger's Avatar
This whine may be heard in RWD vehicles only. One less thing for me to worry about
Old 03-07-17, 05:11 PM
sktn77a
sktn77a's Avatar
The TSB applies to 2013-2015. I noticed it on a 2015 I test drove. The whine is very faint and only below 40mph but if it is a transmission alignment issues, then I want to get it fixed.
Owczar
08-13-17 03:02 PM
vanbay
05-31-17 02:03 AM
daryll40
06-25-11 06:14 AM
spinout180
12-03-08 12:34 PM
Quick Reply: 2014 LS460 TSBs
