Blinking Cruise Control
Old 03-21-17, 09:47 PM
capt
capt's Avatar
Thumbs up Thanks!
Originally Posted by CJITTY
Lol..that's hilarious. But plenty of folks are running Win7 32bit with Chinese "Tekstream" and it works just fine. Carista is way easier though
Interesting! I do have an XP machine and other OS to try. I play with mechanics when I feel confident but I'm in I.T. lol
The BT OBII and Techstream CD /USB cable for Toyota / Lexus are both on their way, so see how that goes when it arrives. I might try to find the brake light sensor, I don't want to jump the gun before scanning it but the previous replies seem pretty confident!
Thank you all for the response and clarifications so far
Old 03-22-17, 09:58 PM
capt
capt's Avatar
I had a similar issue and it was the brake stop switch located on the brake pedal area
Bingo! I used carista with a generic BT reader and an old android phone. I also got bonus codes, yay. But there's no fault lights on the dash? Interesting.
Old 03-23-17, 07:10 AM
Lynzoid
Lynzoid's Avatar
so, you are driving a broken car. big whoop...HVAC codes aren't errors... It's just you scanned in the dark or a garage.
ABS errors most probably history. That is why you need techstream, not 'old android phone' and some 'app'.
ps. my bet won, as usual ) where do i collect my winnings?)))
Old 03-23-17, 12:21 PM
capt
capt's Avatar
oh sweet, yes it was in a garage so today at work it only shows the other four. At 92k miles the actuator was replaced so history would be great! The tech stream disk and cable are in the mail, see when that baby comes in.
self actualization is the prize! Haha
Old 03-23-17, 12:44 PM
enoch861
enoch861's Avatar
Did you try resetting the codes to see if Cruise started functioning normally, at least for a little bit?
Old 03-23-17, 01:04 PM
capt
capt's Avatar
No ive left the errors as is, I'm thinking the other scanner is coming no later than tomorrow. I kind of want to see what it brings up before clearing them. I did buy the brake switch just in case, it was inexpensive. Now to see where it's at exactly.
Old 03-24-17, 06:41 AM
Lynzoid
Lynzoid's Avatar
Near the brake pedal obviously. Easy to replace if you got hands. Just don't forget to tweak it so brake lights come on at the right moment.
capt (03-29-17)
Old 03-25-17, 06:27 PM
capt
capt's Avatar
Thanks for the tip, the brake switch is installed and the lights come on as it should, it was adjusted as needed. Cruise control appears in the dash without blinking, now to test drive soon!
Lynzoid (03-26-17)
Old 03-25-17, 06:30 PM
capt
capt's Avatar
For anyone curious about the exact location above the break pedal. Two Phillips screws were the only things that needed to be removed (below the left and right of the knee airbag) in order to release the plastic panel above the gas and break pedal.
SENSAY813 (03-11-22)
Old 03-26-17, 07:12 AM
Lynzoid
Lynzoid's Avatar
Nice one. My bet won.
capt (03-29-17)
Old 03-26-17, 02:28 PM
satiger
satiger's Avatar
Good assessment........
Old 03-29-17, 06:28 PM
capt
capt's Avatar
Thumbs up Resolved
Sure did! Ive been using it just fine these last three days. It was a 25 dollar part 84340-30110 if anyone is looking for stop lamp switch for the 2008 LS460 Base.
Old 03-29-17, 06:45 PM
jmcraney
jmcraney's Avatar
Seems to me, the symptoms for a maladjusted switch and a defective switch would be the about the same. Any failure analysis on the removed switch - is it bad?
Old 03-29-17, 10:58 PM
capt
capt's Avatar
not sure about testing the old one but the stop lights worked just fine prior to its replacement. I adjusted the stop lights to come on about the same as the old one though.
Old 03-30-17, 09:38 AM
Lynzoid
Lynzoid's Avatar
Two pairs of contacts... Second one is a failsafe. One of those goes - stop lights still work, but cruise gets inhibited. On older cars they even used a vacuum valve (inside a brake switch) as a failsafe...
Tlutrick
04-21-19 03:28 PM
dsc07
LS - 5th Gen (2018-present)
22
07-18-18 10:43 AM
damian1237
Hybrid Technology
02-13-17 06:47 PM
propcop
07-10-15 10:26 AM
socal72
SC- 1st Gen (1992-2000)
11-06-11 11:40 PM
Quick Reply: Blinking Cruise Control
