Fuse for the Rain sensing wipers
Old 04-13-17, 09:17 AM
Travisbjr
Travisbjr's Avatar
Default Fuse for the Rain sensing wipers
Where is the fuse for the rain sensing wiper sensor located. My wipers work but the rain sensing doesn't. When the switch is placed in Auto, the blades stroke once and nothing else. This is when it's pouring rain. I live in Oregon and this feature or at least intermittent is almost required. Any help is appreciated.
Travis
Old 04-13-17, 09:39 AM
GHARP57
GHARP57's Avatar
Shoudl be under either dash in a fuse block
Old 04-13-17, 10:37 AM
teedub21
teedub21's Avatar
The auto rain sense wipers on this car are a joke. Wish I just had the old manual delay adjust.
Old 04-13-17, 11:04 AM
dlbuckls10
dlbuckls10's Avatar
Wink
[QUOTE=teedub21;9834393]The auto rain sense wipers on this car are a joke. Wish I just had the old manual delay adjust.[/QUOTE
I agree the rain sensing wipers are different even when you adjust it.
Old 04-13-17, 11:28 AM
Dryrunner
Dryrunner's Avatar
My GL550 has the same problem. 2 strokes and then goes into hyper stroke mode.
Old 04-13-17, 01:24 PM
DJWLDW
DJWLDW's Avatar
Mine have always worked great the harder it rains the faster it goes. Sometimes I turn off the Auto just because they go more than I think they should.
Dennis
Old 04-13-17, 01:47 PM
jmcraney
jmcraney's Avatar
Travis
This may be a dumb question - have you tried to adjust the sensitivity?
Old 04-13-17, 09:21 PM
JiffyPop
JiffyPop's Avatar
Not sure about the fuse but I do know this. If you unplug the rain sensor on the windshield, it will revert back to being a standard adjustable wiper. I had an issue when I had my windshield replaced and the epoxy that held the sensor bracket on failed. I unplugged it and the wipers worked as they do on a normal car. I don't have any pictures now of how to remove it but it's easy. There is a U shaped plastic clip that pulls downwards. That releases the trim.
Good luck!
Old 04-13-17, 09:55 PM
roadfrog
roadfrog's Avatar
The auto wipers on my 08 work perfectly as do the ones on my wifes 2012 CT200. You do have to adjust the sensitivity setting on the stalk, but once adjusted they should work as they should.
Old 04-14-17, 06:19 AM
enoch861
enoch861's Avatar
Compared to my Audi, they're not great. But overall they seem to work just fine - I leave them on auto 98% of the time. Sometimes it almost feels like the sensitivity settings don't work but they do work it's just that the thresholds are very narrow. I do find it despicable that when it rains and the wipers are activated the headlights don't turn on
DavidinCT (04-14-17)
Old 04-14-17, 09:26 AM
DavidinCT
DavidinCT's Avatar
I know on my LS430, using Techstream, it could be changed in the options. I am not sure on the LS460 but, on the LS430 you could disable the auto wipers and make them standard delay
They work about the same as on the LS430 for me, for the most part they are good, but, some very heavy rain it does not go fast and then I just override them.
Old 04-14-17, 10:42 AM
teedub21
teedub21's Avatar
well unfortunately they don't. They go into hyper fast mode at the hint of heavy mist or rain. Or they won't swipe and I eventually have to over ride them because the windshield will be covered in drops.
I just prefer manual adjust. My BMW's were the only cars that the auto wipers seemed to work well on. My Cadillac CTS-V had auto wipers and they were mediocre at best. Not as bad as the Lexus but not great.
Old 04-14-17, 10:46 AM
DavidinCT
DavidinCT's Avatar
If you hate them, go to the dealer or go on ebay and buy Techstream with the cable to use on a laptop. You'll be able to disable it or change all the little features. Use a old laptop and a $15 cable and problem done.
Old 04-14-17, 02:01 PM
teedub21
teedub21's Avatar
I've got the Carista but it won't go that deep in programming. Keep reading you can unhook the sensor and they default to standard adjustable delay.
Old 04-14-17, 04:55 PM
mckellyb
mckellyb's Avatar
Hmph, I've never seen that in fake Techstream.
I'll have to re-dig through there. I think my LF strut decided to go back to regular height, too.
edit: W00T!!!! LF air strut is back to behaving as it should. It looks truly odd being at full-height, on height high, when the other three are dropped a bit.
Quick Reply: Fuse for the Rain sensing wipers
