Shocks
04-22-17, 06:38 AM
Shocks
My ls600hl front end bounces after hitting a bump. Tried different modes no help. Control arms are good .should I look at the shocks?
04-23-17, 04:41 AM
That would be a reasonable assumption.
check for fluid leaks.
How many miles ?
04-23-17, 04:52 AM
Shocks would be the only reason for this. Since yours are air shocks, it will be an expensive fix. Your only option will be replacing them....either with air replacements or converting to coil-overs.
04-23-17, 11:21 AM
If the same part for the 460 you can source rebuilt or used for about 1/2 or 1/3 the price of new.
04-24-17, 02:07 AM
Thanks everyone.Found a leak on driver side shock. Checking for replacement.
04-24-17, 02:29 AM
Is it possible to rebuild this shock? New shock is $1100
04-24-17, 04:00 PM
aye ya ya, 1100$ smackaroos?!!!!
04-24-17, 04:21 PM
I've had several cars with air suspensions and I've never heard of having the air shock rebuilt but I guess it's possible.
04-24-17, 04:25 PM
Spend $995 on BC coil overs and get rid of the air all together.
04-24-17, 06:44 PM
Mechanical inclined just thought someone out there already rebuilt them.I will look into rebuild kits. Would never change to coil over
Jonx
05-06-20 07:12 PM
Riflman
GX - 1st Gen (2003-2009)
10-30-16 12:03 AM
fourspeed
02-06-15 06:20 PM
ftuber01
05-26-13 10:39 AM
jac430
06-14-11 08:35 AM
