Remanufactured steering rack
Old 05-10-17, 08:42 AM
KKRlexus
KKRlexus's Avatar
Default Remanufactured steering rack
Hi Guys,
My 80,000mi 09' LS460L w/air is having some steering issues. Sometimes I have some "on-Center" gritty feel when turning at local speeds. And at any speed above 60mph the car drifts to the left. Wheels, tires, front end, & alignment were checked but Lexus said that my steering rack is bad, and I was quoted about $5k for a replacement.
Does anyone here have any experience with a remanufactured electric steering rack? I've searched already but could not find any answers.
Old 05-10-17, 06:00 PM
slinky
slinky's Avatar
Default Reman rack
I should be getting mine by Friday, AC Delco remans them. I will let you know.
Old 05-10-17, 06:11 PM
Doublebase
Doublebase's Avatar
​​​​​​​AC Delco remans them? How much are they going for?
Old 05-11-17, 06:54 AM
KKRlexus
KKRlexus's Avatar
Thumbs up
Ok Sounds Good
Old 05-11-17, 07:10 AM
DarKnight
DarKnight's Avatar
Rockauto sells them, check their website.
Doublebase (05-14-17)
Old 05-13-17, 08:27 PM
slinky
slinky's Avatar
Default Rack
mine cost $625.00 but did not show up as of yet, maybe monday. rock auto has them,,Cardone is out of stock though, only AC Delco.
Old 05-14-17, 04:07 AM
Doublebase
Doublebase's Avatar
Looks like the AC Delco racks are $540 with a $200 core. That doesn't sound all that bad. Good to know if I ever need one. And A1 Cardone rebuilds them for $430...probably somethi I wouldn't consider because why ship your rack and wait for it to be rebuilt and shipped back when you can get a remanufactured unit for a hundred more?
The question I guess I would have is, do these have to be programmed or are they just plug and play? I imagine if you install it in the same position the old one came out, and make sure the tie rods are adjusted the same...you should be good. Not sure though.
Old 05-19-17, 07:19 AM
KKRlexus
KKRlexus's Avatar
Did you get your Steering Rack replaced yet? I'm hoping for some good news.
Old 06-06-17, 03:47 PM
KKRlexus
KKRlexus's Avatar
Did anyone notice any front-end vibrations because of the Steering Rack?
Old 06-06-17, 08:03 PM
sktn77a
sktn77a's Avatar
Not personally (haven't had a bad steering rack). While a bad steering rack could conceivably cause vibration, bad control arms are the more likely culprit. Did they check those?
Old 06-07-17, 10:53 AM
UDel
UDel's Avatar
Originally Posted by KKRlexus
Hi Guys,
Is there anything with this car that goes bad that does not cost thousands of dollars to fix at the dealership.
I definitely would not pay that for a fix/replacement, it is just a big waste of money. Take it to a independent or Toyota dealership and see what they say or the prices they give because Lexus dealership prices are just ridiculous.
Old 06-07-17, 11:17 AM
roadfrog
roadfrog's Avatar
Still better than anything else in it's class out there. Heck, fixing ANYTHING at ANY dealership is expensive. My car has never been to the dealer for anything other than a transmission flush and brake flush. EVER.
Old 06-07-17, 11:27 AM
UDel
UDel's Avatar
Don't know if a bad steering rack is a DIY option especially when dealing with a airbag system.
Just because the LS may be better then notoriously unreliable Germans it is still not a excuse especially when they are charging over $5000 to fix a bad steering rack. I never even heard of needing a new steering rack on a modern car with less then 100K miles and am shocked others have had the same issue with this car, why did they not design the steering rack/system to be more durable?
Old 06-07-17, 11:52 AM
roadfrog
roadfrog's Avatar
But it IS durable. How many people here at CL have posted about POSSIBLY having steering rack problems? This is pretty much the first....AND WE HAVEN'T EVEN DETERMINED IT IS A STEERING RACK PROBLEM.
So in my opinion, it's durable.
Old 08-07-17, 10:35 AM
KKRlexus
KKRlexus's Avatar
How did it go with your remanufactured steering rack?
ViPeRs103
10-28-13 03:33 PM
white ls
11-08-08 08:19 PM
Quick Reply: Remanufactured steering rack
