97,000 What to do
Old 06-04-17, 06:53 AM
Chaos236
Chaos236's Avatar
Default 97,000 What to do
My Indy is replacing my shocks/struts at 97K. Mainly because I just want to. Tranny has been done also plugs. Anything else while he has the car would you recommend? He's very reasonable and picks it up for a couple day so"While your in there" suggestions appreciated.
Old 06-04-17, 09:02 AM
sktn77a
sktn77a's Avatar
Definitely have him carefully inspect the front control arms. Brake fluid flush? Check Brakes - they typically last around 100,000 miles.
Old 06-04-17, 09:14 AM
RayLS
RayLS's Avatar
Replace engine coolant - part of the 100k mi service
120 Months or 100,000 Miles ❏ Replace engine oil and oil filter; reset reminder light ❏ Rotate tires1 ❏ Measure thickness of brake pads and rotors (GS, IS, LS2) ❏ Replace air conditioner filter (LS, SC) ❏ Replace engine coolant (see page 67) ❏ Visually inspect brake pads and rotors
Old 06-06-17, 08:50 AM
roadfrog
roadfrog's Avatar
You should also replace the rear diff fluid.
farmerchen
11-30-16 12:16 PM
Parsa
06-16-16 02:16 PM
bryan11
12-12-14 02:32 PM
timucla
08-19-08 11:09 AM
ferix
10-30-07 12:07 AM
Quick Reply: 97,000 What to do
