Opinions on two 2013 LS460's
#31
A little off-topic (and maybe covered elsewhere), but is there any reason people are looking for the L (long wheelbase) version other than to provide more room for backseat passengers? Thanks.
#32
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
The LWB comes with more standard features was my reason. The LWB provides more rear leg but the SWB is also roomy.
#33
L has following features over base;
- Of cause additional 6 inch leg room (same frame as flagship 600HL)
- All around double pane glass windows for added sound isolation
- Headlamp washers - std
- Power door closure - std
- One touch trunk open-close - std
- climate control front seat and heated rear seat - std
- Heated steering wheel - std in L and AWD
- Intuitive parking assistance - std
- Individual vanity mirror for rear - std
- Intelligent high beam - std
LatinLS430 (07-20-17)
#34
You can identify Dynamic Radar Cruise Control (DRCC) by the Lexus emblem being solid up front, in the grill, and the following icon on the steering wheel:
A dead giveaway of air suspension is the presence of the "Height High" button. Depending on year of LS 460, it looks like below (07-12 on the left, 13+ on the right):
I have not experienced a bad air strut first-hand, but others that have commonly report a characteristic clunking sound when going over bumps.
So this 2010 LS is pretty loaded then?
#35
#36
I wouldn't consider this 2010 as "loaded". It is missing the reclining and cooled rear seats, as well as no rear audio controls, no rear cooler box, no separate rear AC unit, no rear vibration/massage, and no rear side-sunshades (basically the Ultra Luxury package) -- but not an issue if you don't carry many passengers, they would already enjoy the extra legroom as it is. Also, without those rear seat upgrades you end up with a larger trunk! It does have the upgraded Mark Levinson audio system and has DRCC. The driver's side armrest also appears to have dark stains. But the big kicker for me is the VIN does not appear to have the updated control arms (see attached). Overall, I think it is a decent example and nice color combo inside and out. I would use the stains, control arms, and possible air suspension maintenance, as bargaining tools. Also, don't forget to register on the Lexus driver's site to inspect the maintenance history on the car. I would have seriously considered this example if I came across it six months ago and the maintenance record checked out.
I did check the history on the Lexus website and it shows that it go the control arms replaced last year as well as a tranny fluid exchange. Also a replacement of fuel pressure gasket. Several batteries were replaced as well. Not sure what this means : ALC VGRS ECU UPDATE
Looks like it's been maintained quite well and repaired when needed by Lexus dealers.
SERVICE HISTORY FOR: 2010 LS460L
VIN: JTHGL5EF0A5039318
Filter History By Year
ALLAll 2017 2016 2015 2014 2013 2012 2011 2010
85095 MILES
DATE: 04/03/2017REPAIR# 0773315
REPORTED BY: Superstition Springs Lexus
SERVICE:
DESCRIPTION: ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN A ~ ~ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN ANY VEHICLE.IF FOUND DOUBLE STACKED, IMPROPER FITMENT OR WRONG FLOOR MAT, IT WILL BE PLACED IN TRUNK AREA FOR SAFETY. ~ ~ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN A
SERVICE: MULTI POINT INSPECTION
DESCRIPTION: MULTI POINT INSPECTION ~ ~MULTI POINT INSPECTION ~ ~ ~ ~85095 SEE MPI
SERVICE: OIL CHANGE
DESCRIPTION: OIL CHANGE ~ ~OIL CHANGE ~ ~ ~ ~85095 OIL CHANGE 30 PERFORMED OIL CHANGE PER CUSTOMER
80496 MILES
DATE: 09/12/2016REPAIR# 0763254
SERVICE: BATTERY COMB: BATTERY
DESCRIPTION: BATTERY COMB: BATTERY ~ ~BATTERY REPLACEMENT - RO#739255, 4/14/2015, 71,406MILES ~ ~. ~ ~80496 BAD CELL 60 REPLACED BATTERY WITH NEW LEXUS BATTERY. OP-190011A 0.6HRS T1 71 T2 71
80150 MILES
DATE: 08/25/2016REPAIR# 0762097
SERVICE:
SERVICE: AUTOMATIC TRANSMISSION FLUID EXCH
DESCRIPTION: AUTOMATIC TRANSMISSION FLUID EXCH ~ ~AUTOMATIC TRANSMISSION FLUID EXCH ~ ~ ~ ~80145 100 COMPLETED TRANS SERVICE
SERVICE: OIL CHANGE
DESCRIPTION: OIL CHANGE ~ ~OIL CHANGE ~ ~ ~ ~80145 LOF 30 COMPLETED LOF
SERVICE: PERFORM 4 WHEEL ALIGNMENT. SET TO FACTORY SPECIFICATIONS
DESCRIPTION: PERFORM 4 WHEEL ALIGNMENT. SET TO FACTORY SPECIFICATIONS ~ ~PERFORM 4 WHEEL ALIGNMENT. SET TO FACTORY SPECIFICATIONS ~ ~ ~ ~80145 160 COMPLETED ALIGNMENT
SERVICE: REPLACE AIR FILTER
DESCRIPTION: REPLACE AIR FILTER ~ ~REPLACE AIR FILTER ~ ~ ~ ~80145 DIRTY 20 COMPLETED
SERVICE: SUSPENSION REPAIR
DESCRIPTION: SUSPENSION REPAIR ~ ~SUSPENSION REPAIR ~ ~ ~ ~80145 UPPER AND LOWER CONTROL ARMS TORN 610 REPLACED ALL 4 UPPER AND 2 LOWER CONTROL ARMS
76197 MILES
DATE: 12/08/2015REPAIR# 0750196
SERVICE:
DESCRIPTION: ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN A ~ ~ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN ANY VEHICLE. IF FOUND DOUBLE STACKED,IMPROPER FIT OR WRONG FLOOR MAT, IT WILL BE REMOVED AND PLACED IN TRUNK AREA FOR SAFETY. ~ ~NEVER INSTALL FLOOR MAT UPSIDE DOWN DRIVERS AREA. AFTERMARKET OR NOT, NEVER STACK FLOOR MATS.ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN ACUSTOMER CHOSE AT THIS TIME TO NOT HAVE THE REPAIRS / MAINTENANCE PERFORMED AS RECOMMENDED ~ ~CUSTOMER CHOSE AT THIS TIME TO NOT HAVE THE REPAIRS / MAINTENANCE PERFORMED AS RECOMMENDED ~ ~ ~ ~76197 CUSTOMER WAS INFORMED ALL AIR FILTERS ARE DIRTY 189.00. HVAC SERVICE 119.95. TRANS FLUSH 369.95. ALIGNMENT 139.95CUSTOMER CHOSE AT THIS TIME TO NOT HAVE THE REPAIRS / MAINTENANCE PERFORMED AS RECOMMENDED
SERVICE: MULTI-POINT VISUAL INSPECTION
DESCRIPTION: MULTI-POINT VISUAL INSPECTION ~ ~MULTI-POINT VISUAL INSPECTION ~ ~ ~ ~76197 PERFORMED MULTI POINT INSPECTION
SERVICE: OIL CHANGE
DESCRIPTION: OIL CHANGE ~ ~OIL CHANGE ~ ~ ~ ~76197 30 PERFORMED LOF
SERVICE: ROTATE ALL TIRES
DESCRIPTION: ROTATE ALL TIRES ~ ~ROTATE ALL TIRES ~ ~ ~ ~76197 ROTATED TIRES
72591 MILES
DATE: 06/25/2015REPAIR# 0742669
SERVICE:
DESCRIPTION: COMPLIMENTARY TOP OFF OF FUEL TANK WITH 91 OCTANE FUEL AS A ONE-TIME GOODWILL GESTURE IN THE INTER ~ ~COMPLIMENTARY TOP OFF OF FUEL TANK WITH 91 OCTANE FUEL AS A ONE-TIME GOODWILL GESTURE IN THE INTEREST OF CLIENT SATISFACTION. ~ ~. ~ ~72591 TOPPED OFF FUELCOMPLIMENTARY TOP OFF OF FUEL TANK WITH 91 OCTANE FUEL AS A ONE-TIME GOODWILL GESTURE IN THE INTERCLIENT AUTHORIZES SUPERSTITION SPRINGS LEXUS TO WASH THE VEHICLE AFTER REPAIRS. SUPERSTITION SPRIN ~ ~CLIENT AUTHORIZES SUPERSTITION SPRINGS LEXUS TO WASH THE VEHICLE AFTER REPAIRS. SUPERSTITION SPRINGS LEXUS IS NOT RESPONSIBLE FOR VALUABLES LEFT IN THE VEHICLE OR BODY DAMAGE OF ANY TYPE. ~ ~..CLIENT AUTHORIZES SUPERSTITION SPRINGS LEXUS TO WASH THE VEHICLE AFTER REPAIRS. SUPERSTITION SPRIN
SERVICE: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H
DESCRIPTION: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H ~ ~ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H ~ ~. ~ ~72591 ELF AGGB7B 410 PERFORMED ELF T1-ELF T2-ELF
SERVICE: LOANER VEHICLE
DESCRIPTION: LOANER VEHICLE ~ ~LOANER VEHICLE ~ ~. ~ ~72591 PROVIDED LOANER
71406 MILES
DATE: 04/14/2015REPAIR# 0739255
SERVICE:
DESCRIPTION: PERFORM 10,000 MILE SERVICE WHICH INCLUDES REPLACING THE OIL & FILTER, ROTATE AND BALANCE ALL 4 TI ~ ~PERFORM 70,000 MILE SERVICE, INCLUDES REPLACING ENGINE OIL & FILTER, ROTATE & BALANCE ALL TIRES, TEST BATTERY, CLEAN BATTERY TERMINALS & INSTALL ANTI-CORROSIVE PADS, OBDII ENGINE SCAN, MULTI-POINT INSPECTION & RESET MAINTENANCE LIGHT ~ ~ ~ ~71406 140 PERFORMED 70,000 MILE SERVICE MAINTENANCE. ROAD TEST.PERFORM 10,000 MILE SERVICE WHICH INCLUDES REPLACING THE OIL & FILTER, ROTATE AND BALANCE ALL 4 TIALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN A ~ ~ALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN ANY VEHICLE. IF FOUND DOUBLE STACKED,IMPROPER FIT OR WRONG FLOOR MAT, IT WILL BE REMOVED AND PLACED IN TRUNK AREA FOR SAFETY. ~ ~NEVER INSTALL FLOOR MAT UPSIDE DOWN DRIVERS AREA. AFTERMARKET OR NOT, NEVER STACK FLOOR MATS. ~ ~71406 INSPECTED MATALWAYS CHECK FOR PROPER FITSIZE OF DRIVERS FLOOR MAT IN VEHICLE.NEVER DOUBLE STACK FLOOR MATS IN A
DESCRIPTION: LOANER VEHICLE ~ ~LOANER VEHICLE ~ ~ ~ ~71406 PROVIDED LOANER
SERVICE: MISC. MAINTENANCE
DESCRIPTION: MISC. MAINTENANCE ~ ~PERFORM CERTIFIED FIRST COMPLIMENTARY SERVICE ~ ~PERFORMED COMPLIMENTARY FIRST SERVICE PER CERTIFIED STANDARDS.
DESCRIPTION: MULTI-POINT VISUAL INSPECTION ~ ~MULTI-POINT VISUAL INSPECTION ~ ~ ~ ~71406 PERFORMED MPI
SERVICE: REMOVE AND REPLACE BATTERY UNDER WARRANTY
DESCRIPTION: REMOVE AND REPLACE BATTERY UNDER WARRANTY ~ ~DURING INSPECTION THE BATTERY FAILED LOAD TEST. LAST REPLACED 8/12/14 ~ ~. ~ ~71406 60 FOUND BATTERY FAILED LOAD TEST. TEST CODE C1CP. REMOVED AND REPLACED BATTERY. VERIFIED OPERATION. OP 190011A, T1-72, T2-71
SERVICE: REPLACE, MOUNT AND BALANCE FOUR TIRES
DESCRIPTION: REPLACE, MOUNT AND BALANCE FOUR TIRES ~ ~REPLACE, MOUNT AND BALANCE FOUR TIRES ~ ~ ~ ~71406 150 MOUNTED AND BALANCED 4 NEW YOKOHAMA ENVIGOR AVID TIRES.
66056 MILES
DATE: 08/12/2014REPAIR# 0728065
DESCRIPTION: BATTERY COMB: BATTERY ~ ~GUEST STATES THAT THE BATTERY HAS NEEDED TO BE JUMPED. TEST AND ADVISE ~ ~. ~ ~66056 190011A 60 REPLACED BATTERY OPT CODE 190011A T1:72 T2:99 HOURS:.60
SERVICE: CERTIFIED PRE-OWNED 1ST OIL CHANGE
DESCRIPTION: CERTIFIED PRE-OWNED 1ST OIL CHANGE ~ ~PERFORM CERTIFIED FIRST COMPLIMENTARY SERVICE ~ ~PERFORMED COMPLIMENTARY FIRST SERVICE PER CERTIFIED STANDARDS. ~ ~66056 30 PERFORMED OIL AND FILTER CHANGE
DESCRIPTION: MISC. MAINTENANCE ~ ~GUEST STATES AT HIGHER SPEEDS THERE IS A LOT OF WIND NOISE COMING IN TO THE CABIN ~ ~ ~ ~66056 TEST DROVE VEHICLE. COULD NOT DUPLICATE NOISE SOUNDS NORMAL
DESCRIPTION: ROTATE ALL TIRES ~ ~ROTATE ALL TIRES ~ ~ ~ ~66056 40 PERFORMED TIRE ROTATION
55014 MILES
DATE: 07/26/2013REPAIR# 0300130
REPORTED BY: Bell Lexus North Scottsdale
SERVICE: 55000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 55000 MILE SERVICE NON WARRANTY-NON OEM ~ ~PERFORM 55,000 MILE SERVICE. CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVES AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. CHECK POWER STEERING FLUID ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~55,000 MILE SERVICE PERFORMED TIRES 5/32"" ON ALL WHEELS /BRAKES F:5MM R:8MM
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~INSTRUCTION/NOTES BELL LEXUS HAS PROVIDED A LOANER FOR YOU. WE ONLY ASK A $10.00 PARTICIPATION TO OFFSET FUEL AND MAINTENANCE COSTS. PLEASE RETURN BY 6PM WHEN YOUR VEHICLE IS FINISHED OR A $50.00 RENTAL CHARGE PER DAY WILL BE ADDED TO YOUR INVOICE LOANER# ~ ~ ~ ~LOANER
50279 MILES
DATE: 05/13/2013REPAIR# 0294438
SERVICE: 50000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 50000 MILE SERVICE NON WARRANTY-NON OEM ~ ~PERFORM 50,000 MILE SERVICE. CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. CHECK POWER STEERING FLUID ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~50,000 MILE SERVICE PERFORMED TIRES 7/32 BRAKES FR 5MM REARS 7MM
45402 MILES
DATE: 02/20/2013REPAIR# 0288084
SERVICE: 45000 MILE SERVICE NON WARRANTY
DESCRIPTION: 45000 MILE SERVICE NON WARRANTY ~ ~PERFORM 45,000 MILE SERVICE. CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. REPLACE AIR FILTER CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. INSPECT ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~45,000 MILE SERVICE PERFORMED TIRES 8/32 BRAKES FR 6MM REARS 8MM
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~REPLACE A/C AIR FILTER. ~ ~ ~ ~REPLACED A/C FILTER(S)NON WARRANTABLE OPERATION CODE ~ ~PERFORM 4 WHEEL SPIN BALANCE MAINTENANCE ~ ~ ~ ~BALANCED ALL FOUR TIRESNON WARRANTABLE OPERATION CODE ~ ~INSTRUCTION/NOTES BELL LEXUS HAS PROVIDED A LOANER FOR YOU. WE ONLY ASK A $10.00 PARTICIPATION TO OFFSET FUEL AND MAINTENANCE COSTS. PLEASE RETURN BY 6PM WHEN YOUR VEHICLE IS FINISHED OR A $50.00 RENTAL CHARGE PER DAY WILL BE ADDED TO YOUR INVOICE LOANER# ~ ~ ~ ~LOANER
SERVICE: WHEEL ALIGNMENT
DESCRIPTION: WHEEL ALIGNMENT ~ ~PERFORM FOUR WHEEL ALIGNMENT MAINTENANCE ~ ~ ~ ~PERFORMED FOUR WHEEL ALIGNMENT
40153 MILES
DATE: 11/13/2012REPAIR# 0280457
SERVICE: 40000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 40000 MILE SERVICE NON WARRANTY-NON OEM ~ ~PERFORM 40,000 MILE SERVICE. CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. CHECK POWER STEERING FLUID ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~40,000 MILE SERVICE PERFORMED TIRES FR 8/32 REARS 9/32 BRAKES FR 7MM REARS 8MM
SERVICE: INSPECT BATTERY CHARGE LEVEL INSPECT BATTERY CHARGE LEVEL
DESCRIPTION: INSPECT BATTERY CHARGE LEVEL ~ ~TECH NOTED AT TIME OF SERVICE THAT BATTERY FAILED LOAD TEST ~ ~BATTERY FAILED LOAD TEST CODE# C1CP ~ ~REPLACE BATTERY
34955 MILES
DATE: 07/26/2012REPAIR# 0272155
SERVICE: 35000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 35000 MILE SERVICE NON WARRANTY-NON OEM ~ ~PERFORM 35,000 MILE SERVICE CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. CHECK POWER STEERING FLUID ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~35,000 MILE SERVICE PERFORMED TIRES 0/32 SEPARATING AND INTO THE SECONDARY RUBBER RECOMMEND AN ALIGNMENT BRAKES FR 7MM REARS 8MM
29763 MILES
DATE: 05/01/2012REPAIR# 0265669
SERVICE: 04 30,000 MILE SVC
DESCRIPTION: 04 30,000 MILE SVC ~ ~PERFORM 30,000 MILE SERVICE. CHANGE OIL & FILTER. LUBE ALL HINGES. INSPECT COOLING SYSTEM & TRANSMISSION FLUID. INSPECT EVAPORATIVE EMISSION SYSTEM & FUEL TANK CAP GASKET. CLEAN THROTTLE BODY AND ADD FUEL SYSTEM CLEANER. ROTATE TIRES & CHECK TIRE PRESSURE ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~30,000 MILE SERVICE PERFORMED TIRES 6/32 BRAKES FR 9MM REARS 10MM
24674 MILES
DATE: 01/05/2012REPAIR# 0256418
SERVICE: 25000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 25000 MILE SERVICE NON WARRANTY-NON OEM ~ ~PERFORM 25,000 MILE SERVICE CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. CHECK POWER STEERING FLUID ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~25,000 MILE SERVICE PERFORMED TIRES FR 6/32 REARS 7/32 BRAKES 10MM
19797 MILES
DATE: 10/11/2011REPAIR# 0249714
SERVICE: 20000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 20000 MILE SERVICE NON WARRANTY-NON OEM ~ ~PERFORM 20,000 MILE SERVICE, CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVEL AND CABLE ENDS. CHECK POWER STEERING FLUID ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~20,000 MILE SERVICE PERFORMED TIRES 7/32 BRAKES FR 10MM REARS 11MM
15117 MILES
DATE: 07/21/2011REPAIR# 0243399
SERVICE: 15000 MILE SERVICE NON WARRANTY
DESCRIPTION: 15000 MILE SERVICE NON WARRANTY ~ ~PERFORM 15,000 MILE SERVICE CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. REPLACE AIR FILTER CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVEL AND CABLE ENDS INSPECT EX ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~15,000 MILE SERVICE PERFORMED TIRES 8/32 BRAKES 10MM
10165 MILES
DATE: 04/27/2011REPAIR# 0236550
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~ ~PERFORM 10,000 MILE SERVICE CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS CHECK POWER STEERING FLUID A ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~10,000 MILE SERVICE PERFORMED TIRES 9/32 BRAKES 11MM
5023 MILES
DATE: 02/03/2011REPAIR# 0229090
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: 5,000 MILE SERVICE ~ ~PERFORM 5,000 MILE SERVICE CHANGE OIL AND OIL FILTER AND ROTATE TIRES CHECK TIRE PRESSURE AS WELL AS CONDITION OF TIRE. INSPECT AIR FILTER CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. INSPEC ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~5000 MILE SERVICE PERFORMED TIRES 9/32 BRAKES FR 11MM REARS 12MM
2110 MILES
DATE: 12/08/2010REPAIR# 0224467
SERVICE: 1,000 MILE SERVICE
DESCRIPTION: 1,000 MILE SERVICE ~ ~PERFORM 1000 MILE SERVICE ( ALL MODELS ) CHECK ALL FLUID LEVELS, TOP OFF AS NEEDED. INSPECT FOR ANY OIL LEAK. CHECK NUTS AND BOLTS ON BODY, CHASSIS AND WHEELS. CHECK HEADLIGHT ALIGNMENT AND AIM IF NEEDED. CHECK LIGHTS, ACCESSORIES AND TIRE PRESSURES. CLEA ~ ~ ~ ~PERFORMED 1,000 MILE SERVICE
72 MILES
DATE: 06/28/2010REPAIR# 0411460
REPORTED BY: Lexus San Diego
SERVICE: CAMPAIGNS
DESCRIPTION: CAMPAIGNS ~ ~ALC VGRS ECU UPDATE ~ ~ ~ ~REPLACE STEERING ECU
4 MILES
DATE: 03/10/2010REPAIR# 0401132
SERVICE: STARTER (REDUCTION TYPE)
DESCRIPTION: STARTER (REDUCTION TYPE) ~ ~ ~ ~ ~ ~PDI 2.0 254
#37
So much for Lexus' "Free" loaner cars... What's with the $10 "Participation" charge? Hope this doesn't creep into other Lexus dealers' standard operating procedures. It's not that I can't afford the $10 loaner charge, it's the principle of the thing... More erosion of the magical Lexus service experience...
#38
I have always been under the impression that Lexus production for a model year is September, so I purposely tried to find a '10 that was very late production (and therefore my car was 2 months away from being considered a 2011 model year) in an attempt to mitigate the risk of having to replace the control arms from the prior design. Thanks for any help.
#39
I've been keeping my eye on this 2010 LS460L:
http://www.sslexus.com/VehicleDetail...-AZ/3016204463
The price went down from high 27k last month.
What do you guys think? I really like the color combo. I don't necessarily need the room of a LWB since it's just me and my gf riding.
Looks like the car has been regularly maintained by Lexus dealers.
#40
I recently bought a '10 L (July production) - I looked at the PDF you attached which is very helpful regarding the control arm change. I want to make sure I understand correctly - it says for an "L" the models produced BEFORE effective VIN with last 6 digits 040325 would have the older control arm design. I just looked at my VIN and this may be a really stupid question, but how do you determine if your car VIN is beyond that? Is it like an odometer reading? So for example 040327 would be AFTER 040325? And my car has 041XXX so would that be considered AFTER?
jrmckinley (07-21-17)
#41
Just took my 11' production year in for service. Has 55K miles on it. Was informed both control arms need to be replaced. They are cracked I believe he said. I assumed mine had the updated control arms based on the model year but I guess it doesn't matter. I think they are about $1350 a piece. So, control arm issues could be any year even if it is believed the car has the updated kind. Glad the CPO is covering it.
I can't believe this car is still not gone.
#42
Markets are different, but that seems like a pretty reasonable asking price. I think you could get $1,500-$2,000 off. Again, markets are different, but here in FL I just bought a 2010 460 L in February with 20k less miles and the asking price was $25,800 (down from $29k). Down here, I found every 10k of additional miles translated to a reduction in asking price of $1k, which is why I think your car is pretty similarly priced to mine. I don't remember my final purchase price, but think it was somewhere around or just below $24k. FWIW, my car had brand new tires, the 5 star wheels but didn't have air ride. I still think you have some wiggle room on that car. Without knowing the taxes and fees in your area, I'd probably offer them $23,500 OTD and see what they say. The reality is it's 8 model years old and has almost 100k miles. It's an attractive car for lots of folks on this forum, but the general market demand is going to be pretty low (my car sat on the lot for 5 months before I snagged it). I'd ask them how long they've had it- They may have to wholesale it soon (some places can't keep cars longer than 60 days), so that should tell you that you can low ball the offer. Your goal is to be about $500 more than what they'll get to the wholesale market and they'll do the deal.
#43
#44
Curious if you looked into the warranty? My guess is it would be very $$$. Due to age I don't think it comes with the CPO warranty since it is over 6 years old (a sales guy once told me if I recall correctly).
