adding another sub amp
Where should I tap into to get a signal for my new sub box?
not the factory sub signal...it cuts down when the volume is turned past a certain level.
Anyone have a wiring diagram for the ML amp for me to pull a signal from??
thanks
thanks
Grabbing the signal before its amplified would be ideal if I had a diagram of the factory (ML) wire harness...or after its amplified using an LOC...either way would work really.
looks like im the only one who wants to add a sub to the factory setup
The sub channel on ML amps are designed to lower the sub output to keep it "balanced" with the rest of the system after a "certain point". I want to pull a full range signal that doesnt have the factory sub frequency cut off..id like to tune it (sub-range) myself.
looks like im the only one who wants to add a sub to the factory setup![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
GR6RR (07-19-17)
AP2
12-10-14 10:40 AM
BRIUHNz
10-02-07 07:24 PM
