LS460 Air Condition Code
I am gettting air condition fault codes 24 and 97. Does anyone know what these codes mean?
When the car is off after a certain amount of time and then started the air condition will turn off and the set temperature will default to 75 degrees. I have read several threads on this but could not find the codes 24 and 97 on the charts that were posted. It is a 2007.
Thanks
Thanks
No but the battery is less than a year old. All of this started happening when I changed the cabin air filter. I did disconnect the battery for several minutes to see if the ac would reset and it did not.
joedaddy1 (10-20-22)
97 is likely the ac amp (computer module), likely the connector needs a good wiggle and check for green corrosion. If you changed the cabin filter, it's to the left of the door and may have been jostled.
LANewsboy (11-02-22)
I have a 2011 ls460l and climate codes 44 54 57 and 59 popped up. What could that mean?
Intermittently, I have no heat from passenger side front and rear.
Please help. Thanks
Please help. Thanks
I have the same problem after replacing the cabin air filter.
I'd like to try the suggested fix, but can anyone tell me what the ac amp computer module looks like?
I have a hard time seeing anything in that space, with my ancient knees and eyes!
Thanks....
Thanks....
Hi LANewsboy,
There is a typical issues folks have after the cabin air filter change. Blend door might be busted (not moving regardless of fresh or recirculation setting & hearing some gears moving when the setting is changed). I had the additional behavior where my temp setting was always back to 75 for a cold start. There is a sticky reference that describes how to open up your glove box to diagnose and get a better look at it. My linkage was disconnected as described in post #29 in the following link. I was lucky that my linkages weren't broken in pieces and was able to re-link them with a normal screwdriver. Fairly easy fix. Good Luck, Jeff
https://www.clublexus.com/forums/ls-...-broken-2.html
