60K Maintenance
Just a side note, i just got the 30k service done, and so far, the car seems much more responsive (probably just me). No stalling or loss of power after the engine oil change (synthetic)... yet.
Here's what the Factory "Required" 60k Maintenance on a 2011 LS460L would include at the dealer:
- Replace Synthetic Engine Oil & Filter
- Tire Rotation (Same Size Tires Only)
- Comprehensive Multi-Point Vehicle Inspection
- Replace Engine Air Filter
- Replace Cabin Air Filter
- Brake Fluid Service
- Replace Smart Key Battery
- Replace Spark Plugs
- Measure Thickness of Brake Pads & Runout Rotors
- Inspect Brake Pads, Shims and Rotors
- Fill Fluids To Proper Levels As Needed
- Reset Maintenance Reminder Light (If Applicable)
- Inspect Drivers Floor Mat
You're more than welcome to skip changing the spark plugs until up to 120k though. If the car still has warranty coverage, change the plugs so they can't be used against you.
