No audio after startup
GM everyone, I'm having an issue where when I first start the car the is no audio from ANY of the sources. After a couple of minutes the audio kicks in. I've read lots of the stuff on the ML amp issue so I'm kind of well versed in that respect. I just want your opinions on what could be the issue and is the a sign of imminent amp failure? I would like to note that this first started after it rained if that means anything, I read a couple of threads where ppl complained of this issue when damp outside. My low beams were flickering around the same time so I ordered some new bulbs that should be here tomorrow. Other than that the car performs great. Anyway suggestions are welcome.
I will check the trunk area around the amo to make sure no water is getting in there. This was an issue in the 400 forum when the trunk seal was worn. One thing to note is that I installed a Grom type adapter called Yatour so I could have usb support for music. I'm in the process of pulling the radio back out to make sure the connections are tight.
I think I might have found the culprit. My question is why would anyone place this what seems like cotton in front of the fans? I suspect a tech at the dealership since this vehicle is a 1 owner and serviced exclusively at the Lexus dealer I purchased the car from.
you might need to vacuum this stuff out of the fan vent.
michaelisf
17
04-06-11 01:13 PM
VIPsteelo
02-25-07 07:23 PM
