How to Remove Drip Rails?
I'm trying to decide if I should have my delaminating drip rails painted or just replaced.
Depends on if I can just remove them and bring them to the paint shop.
Any tutorials out there?
Thanks.
Thanks.
Same thing is happening to my drip rails. I bought some carbon fiber wraps from eBay and will wrap the rails when it arrives. I've already removed the drip rails from my car using these tools. I started from the back. I will post the finished product after the carbon fiber wrap is installed on the drip rails.
RussLS460 (03-01-20)
Hi Randy,
Any help?
https://www.clublexus.com/forums/ls-...g-on-roof.html
Another suggestion would be to visit a PDR or collision repair shop. I am positive they will know how to remove them. Hopefully, they will be friendly enough to give you some directions. Good luck!
Wood3000 (03-04-21)
After paint tape removed and glue cleaned.
Had the same issue w 2010 GS350. Lexus wanted $1200 to repaint them. Stopped at Carsmetics. He said he’d repaint them for $300 but no warranty. They’re stainless steel and he couldn’t warranty how long the paint would last in the hot Florida sun. His body shop person came out and peeled off the remaining tape (I had tried but it was tearing off in pieces) all in one piece. I think being 95 degrees out helped. When I tried in my garage, it just tore. He then used a lacquer thinner, very lightly, to remove the glue residue. I gave him a $20 tip and left them unpainted. They look fine
I left the rails on. When you start peeling it will break and you will need to tease the edges up to continue pulling. Try to lead with the removal in such a way as to first peel up the edges that wrap the rails. Just take your time.
Has anyone tried using a heat gun or blow dryer to soften the adhesive and make the removal easier?
jchou0615
07-06-10 12:00 AM
