LED Conversion Ongoing
Hi
I have done a lot or research to convert mostly interior lights to LED. I purchased a supply of 194 LED bulbs. The trunk lights went fine and look great. The next ones were the bottom of the door interior courtesy lights. I started with the driver's door. Problem was when I plugged in the 194 LED it was very dim. I switched it around since I know of the polarity issue. The other way doesn't work at all. I put it back to the original way, still very dim. I tried a different bulb, same results. I tried to put back in the original bulb, no light at all.
Then I put the LED back in, and same results, dim light if you have it the correct polarity. I tried pushing the door's switch to see what would happen. When I push the switch, the light got brighter!! This doesn't make sense, why would it get brighter when the door is shut and dim when it opens? I tried the original bulb, nothing with the switch pushed in or not.
All worked fine until I started messing with it, right now no light at all because I put the original back it as I didn't want the LED burning bright while the door is shut.
ANY advice?
ANY advice?
What year is your LS?
I did a full led conversion on my ‘13 minus the vanity lights (prefer that as natural) using led circuit boards, not the cheap festoon bulbs. Results are quite literally night and day. May be too bright for some, but I love it.
All the other ones went in fine. I checked with a multimeter but not real sure of what I am looking for. Still doing the same thing, no light at all from incandescent, but led will glow faintly with door open, gets brighter when door closed button is pushed.
I have seen threads about this issue before, there is a door lights controller that go bad when bulb terminals are shorted. I don’t recall the name of the controller but a search will find it.
rclab1
01-12-08 11:16 AM
